The FIAT Forum
Old 11-12-2007   #1
Trader Rating: (0)
Clutch replacement
Does anyone know where i can get any information about changing a clutch on a seicento, or has got a quick guide?
Tom.H
bobbob is offline
Old 12-12-2007   #2
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: Clutch replacement
Haynes Cinq manual is your best bet. While it ain't brain surgery, it's an awkward job.
fingers99 is offline
Old 13-12-2007   #3
Trader Rating: (0)
i just really need to know things like:-
-Were the hell is the start motor and does it need to come off?
-is there an easier way to get the ball joints off, instead of just banging the crap out of them?
-which plug on the bottom of the gearbox is the best to get the gearbox oil out off?
-where do i fill it back up?
-is there an easy way to get the gear linkages off instead of the hammer way (i got the top one off lol)?
-is that dodgy looking sump going to be able to hold the weight of the engine, (and gearbox if needed to)?
at the mo meant it just seems like me and my hammer are getting no where
Thanks loads
Tom.H
bobbob is offline
Old 13-12-2007   #4
kritip's Avatar
Trader Rating: (3)
kritip has donated! United Kingdom
ITs all here if you search.
Starter motor at rear of box at top , has to come off.
You can unbolt the wishbones, and get the driveshafts out without breaking ball joints if your careful.
Drain is by the rear mount. Filler is halfway up on the front.
I just slipped an appopriate sized spanner uner the linkage joints and levered them off in seconds.
Sump will take the weight. I used a block of wood to spread the load.
Kristian
Black Seicento Sporting mk2
1242cc 16V conversion finished and removed!
Megasquirt installed, a constant evolution
1368cc and 6 speed running great now
My Members Motors thread
kritip is offline
Old 15-12-2007   #5
Trader Rating: (0)
Thanks loads... sorry about the being spoon fed, but its all good, will try harder to search more next time
Tom.H
bobbob is offline
The following user says "Thank You!" to bobbob for this useful post:
East Mids Neil (16-12-2007)
Old 16-12-2007   #6
Trader Rating: (0)
To remove a stubborn ball joint here's a method I've use on various cars:
Jack & support the car / Remove the road-wheel / Place scissor jack under the Disc and raise it (this prevents the strut from absorbing the shock of the hammer blows) / Undo the ball joint nut but not fully (this protects the threads on the ball joint) / Whack the nut and it usually comes off very easily / When refitting use a new nut
East Mids Neil is offline
Old 16-12-2007   #7
kritip's Avatar
Trader Rating: (3)
I've just used a 2 prong hub puller on thoses ones in the past as well.
kritip is offline
Old 16-12-2007   #8
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
I would never hit the top of any ball joint unless it was being scrapped.
Smote the side of the wishbone to shock it free.
D
rallycinq is offline
Tags
clutch, replacement, seicento
(G) Clutch cable replacement - how? Urgent help please yellow_sei Cinquecento / Seicento 14 03-12-2007 01:13
multipla clutch replacement ahollyhead@uavenginesltd. Multipla 2 25-07-2007 15:49
(T) Changing hydraulic clutch gearbox to take a cable clutch? 4paws Uno 10 23-03-2006 15:56
(T) Clutch - cable or clutch itself? SnowBord Cinquecento / Seicento 12 13-02-2005 18:18
