| Brighter interior courtesy light replacement and clock troubles Hi there y'all. I'm thinking of getting one of these to replace the courtesy light bulb as the stock bulb is very dim by my reckoning. http://cgi.ebay.co.uk/INTERIOR-LIGHT...QQcmdZViewItem Has anyone tried this or something similar? What have people found? Also, the clock in my cinq has stopped working. I heard that this can be a sign that the battery is failing. I'm borrowing a multimeter from my boss soon so I can check what's going on there, but has anyone else got any ideas... or spare clocks?
| Re: Brighter interior courtesy light replacement and clock troubles if the battery is failing to that extent the car wont start..... those LED lights look bright but dont have much range (if that makes sence )
| | #3 | ||
| mad bad and very very old | Re: Brighter interior courtesy light replacement and clock troubles When you say the clock is not working, is it completely blank, has it changed to all zeros, or is it very faint. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #4 | ||
| Re: Brighter interior courtesy light replacement and clock troubles At first the light behind the clock stopped working but now it doesn't display anything. I'll post the battery readings when I get hold of that multimeter. I understand about the 'range' thing you're talking about, Andy. Has anyone found a way to light their interior better than the stock light? Reading maps this winter could be frustrating with the poor lighting.
| | #6 | |||
__________________ 16v cinq with ITB's ![]() Last edited by Brooky; 02-12-2007 at 22:22. | ||||
| | #7 | ||
| Re: Brighter interior courtesy light replacement and clock troubles I've got a "white" one, which shines a very light blue, localised, the bulb is bright but there's no throw to it.
__________________ http://card.mygamercard.net/sig/Soopahfly82.png Small BHP, BIG dB(a) CCNP, MSCE, Training for Certified Ethical Hacker. | |||
| | #8 | ||
| Sk8 4 Life! | Re: Brighter interior courtesy light replacement and clock troubles ive got a blue one of those LED's off ebay, honestly its useless, not half as bright as the standard bulb, jus looks a bit cooler! hope this helps
__________________ ![]() Cinqy sold!!![]() Now owner of 93 Renault Clio 16v ![]() After a black Cinq Sporting!! ![]() | ||
| | #9 | ||
| Re: Brighter interior courtesy light replacement and clock troubles As above. Very little spread, but cool looking. Fora brightter interior you're better off getting a higher wattage std bulb.
| | #10 | ||
| this is where i stand | Re: Brighter interior courtesy light replacement and clock troubles i have a decent LED bulb from ultraleds and it is much brighter than the standard one.
__________________ | ||
| | #11 | ||
| | #12 | ||
| | #13 | ||
| Re: Brighter interior courtesy light replacement and clock troubles So it looks like I'm looking for a dedicated map reading light. Is there an official/popular replacement for the standard light?
| | #14 | ||
| this is where i stand | Re: Brighter interior courtesy light replacement and clock troubles seems i've gone invisible again.. http://www.ultraleds.co.uk/37mm-leds...te-p-1493.html ^^ just get one of them in the right size.
| | #15 | |||
If you want a dedicated map reading light, then you should place this above your shoulder so the the light is pointing at the map, not in your face. These can easily be mounted with a couple of self tappers to the roof rail. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | |||
| Tags |
| bright, clock, courtesy, interior, light, replace |
| Ulysse front fog light replacement | Jon Holt | Ulysse | 1 | 24-12-2006 02:47 |
