| Fan blows fuse after a while I've read with interest the posts on here about fans and overheating and followed the instructions religiously. My main problem is that the fan will run fine for a while and then blow the fuse. I've run the fan in isolation from the temp switch on the rad and with it connected. I've taken the fan off its mountings (it was catching the rad slightly) and run it and I get the same problem. Now as far as I can work out, the temp switch is fine - the fan starts at 90deg, the fan appears to be fine - runs very smoothly, so I've either got a dead short somewhere, or the fan is past its useful life! Anyone got any ideas to try before I go and shell out for a new fan? Orca M Reg 899 Cinq - my wife's runabout!
| Moderation in Moderation | using the right fuses? mine was doing this and realised i was using fuses with lower rating than i should have been using :p Abarth Kitted Cinq Sporting, New lil siggy pic coming soon, till then.... not much really lol
| | #3 | ||
| 20 amp is what I've been using
| | #4 | ||
| Join Date: Jun 2004 Location: northamptonshire, United Kingdom.
Thanks: 0 Trader Rating: (0) | Hi If it is doing it after a period of time it could be poor connections on your electrical plugs, inspect these and clean if necesary. could even be a bad (loose) conection on your fuse board. sometimes when these fans run for long periods the wiring heats up and causes poor conections usually indicated by rock hard insulation. or if could be just that your fan is on its last legs. worth a look any way
| | #5 | ||
| mad bad and very very old | Fan motor is fubared. The motor is not running fast enough as the bearings have packed up. New fan motor please:( Cheers D Grumpy old git going fast downhill rather than downhill fast!!
| | #6 | ||
| Rallycinq & Helicopter - thanks for confirming. Right which bits are scrap and which bits aren't? I haven't taken the fan off the mounting yet, but can I just replace the business end and keep the blades, or does it come as one unit? Also, advice on whether I should get one from a scrapyard or just buy new would also be appreciated. Orca
| | #7 | ||
| mad bad and very very old | Fraid I dunno, I put a complete waterproof motorsport unit on mine. Sorry D Grumpy old git going fast downhill rather than downhill fast!!
| | #8 | ||
| this is where i stand | the blades and mounting bracket wotsit all come as one when i bought it from fiat. cost around £60 iirc Cinq Sporting - and yes, its broom yellow!
| | klaus23 | Punto | 1 | 30-04-2004 01:37 |
| | westy | Cinquecento / Seicento | 1 | 25-04-2004 05:46 |
| | pramodkumart | Bravo / Brava | 1 | 10-04-2004 13:33 |
| amp fuse / gain | AquaSpirit | I.C.E | 6 | 21-09-2003 15:48 |
| HELP..Injection System Fuse Blowing | Mac | Leisure Lounge | 1 | 14-06-2002 05:00 |
