Thread Tools
Old 10-06-2004   #1
breather filter
:D:Djust seen these things on the net looked like a air filter/k&n shape but smaller for the breather hose that splits from the airbox to the rocker cover wich does away with the say 25% of the air taking a right turn where it splits in the hose from airbox to throttle on a cinq sx they r only 9.99 in motoworld has ne1 ever fitted one of these do you think it would be worth it as i recon about 15% more air would go directly to the throttle instead of spliting and going to the breather tube :D:D
when take it of is sucks loads of air in and idles better
shnowzy is offline Reply With Quote Quote
Old 10-06-2004   #2
HP
Likes going topless.
HP's Avatar
HP has donated!
If you use a K&N or similar, they're fine. If you bang it on the cam cover and don't have some way of drawing the fumes away, the car will ming unbearably of oil mist fumes drawn through the heater.
Pete.
1242cc cinq, turbo cinq, Cinqs&Seis Yahoo group, Clubcento
HP is offline Reply With Quote Quote
Old 10-06-2004   #3
arc
this is where i stand
arc has donated!
from what i understand from your post, you've confused whats going on. the oil breather vents the crankcase fumes into the airbox, theres no air coming from outside into the breather.
if you do fit one tho, as pete has said you need to locate it properly or your car will ming.
mine is on a tube and pushed over t'other side of the bay - like so
http://tackycheese.net/images/misc/cars/cinq/13-05-04/oil_breather.jpg
Cinq Sporting - and yes, its broom yellow!
arc is offline Reply With Quote Quote
Old 10-06-2004   #4
thanks for that
well on my sx the tube that draws the fumes away goes to front of throttle and gets put buck in the mix. there is a tube next to that wich is blocked with a small rubber hose but if i take that hose of the car accelerates better can ne1 tell me why it is blocked? ive been driving around unblocked for days no probs
Old 11-06-2004   #5
HP
HP's Avatar
HP has donated!
'cos it allows extra unfiltered air into the engine.
Pete.
Thread Tools
(G) 1.0 i.e. start (AIR FILTER?????) NIODE Uno 10 29-07-2004 07:21
(T) breather filter fitting (chink) GhostWKD Cinquecento / Seicento 7 19-07-2004 16:48
(T) Pollen filter newportz Punto (Mk2/2b) 3 02-06-2004 14:10
(G) DOES ANYONE KNOW OF A QUITE FILTER max Cinquecento / Seicento 11 22-05-2004 05:23
(T) Filter cleaning yellow_sei Cinquecento / Seicento 7 04-01-2004 23:06
