| Failed My Mot :( :( :( Just had my MOT this morning and guess what.......IT FAILED!!!!! It failed on the following : 1.headlights not being positioned correctly 2.window washer providing insufficient washer liquid 3.emissions 4.exhuast system has a major leak of gases 5. rear brakes recording little or no effort 6.rear parking brake recording little or no effort 7.offside reg plate lamp not working 8.both from suspension arm has excessive play in the ball joints 9. 2 holes in the body work near rear and front body mountings and the guy quoted me £300 to fix the lot!!!!! Im like ur joking!!! I managed to get the parts: arms £66 (brand new) reg bulb 41p spark plugs £7.09 total for parts = £ 73.50 Labour for doing the work : fitting the new arms = £45 per side £90 welding of the 2 holes = £80 total = £170 Grand total!!!! = £ 243.50 IM right gutted!!!!!!!!!!!
__________________ My car represents my life...falling to bits | |||
| Erm........... | Re: Failed My Mot :( :( :( And that's without sorting the brakes out!
__________________ Dirty Yellow Box | ||
| | #3 | ||
| Re: Failed My Mot :( :( :( Got mine tomorrow...
__________________ * * * Pandarus * * * (aka MARTIN) FIATLESS BUT STILL LOVING ANYTHING PANDA!!! 2002 Skoda Fabia Comfort Estate 1.4 MPI | |||
| | #4 | ||
| mad bad and very very old | Re: Failed My Mot :( :( :(
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #5 | ||
| Re: Failed My Mot :( :( :( Blimy, when I first started reading I thought just minor things... headlights... but then I started seeing emmisions, exhaust, suspension..... god your car was a death trap lol.... no offence
| | #6 | ||
| this is where i stand | Re: Failed My Mot :( :( :( hardly a death trap, excessive wear in the front ball joints means they rattle a bit - not likely to fail (yet) new arms only cost around £20 each, so no biggy - and i wouldn't pay someone to fit them, its only a few bolts. rear brakes, just service them. free up the linkages, tap the shoe adjusters in the drum and tighten the handbrake cable, bet they'll be fine. emissions - bung some decent fuel in, some redex and then take the car out for a good thrash. oh and clean/replace your air filter too. (just looking at how to make my car a bit greener come emissions times, i shall be retarding the ignition timing another 10degrees or so.. that'll do it!)
__________________ | ||
| | #7 | |||
__________________ Dirty Yellow Box | |||
| | #8 | ||
| Re: Failed My Mot :( :( :( Arc yesterday i had a go at taking the arms off right, the bolts that hold the roll bar on the arm just snapped clean off lol i wont be able to do it myself there are charging me a maxium of £45 per side lol but while im there im going to get them to tighten the exhaust system up and take off the rear brakes and put them back on because when the brackets come for the rear disc conversion i dont want any snapped bolts or anything!!!
| | #9 | ||
| | #10 | ||
| | #11 | ||
| Re: Failed My Mot :( :( :( should have let me know, iv got a complete exhaust system and 2 lower arms let me know if you need anything else cheers
| | #12 | ||
| Re: Failed My Mot :( :( :( Im right F'd off now the garage that i had to take my car too for the arms to be fitted have charged me £183.30 in labour!!!!! but they said it was a right job as the nuts had sezied etc.. and i got them to make sure the rear conversion would go smoothly as poss by making sure the nuts at the back end were ok... Oh yeah do you think this was the culprit for my emissoin failure??? a cracked spark plug??
| | #13 | ||
| | #14 | ||
| Re: Failed My Mot :( :( :( they look ok better than that one lol there was alot of poping coming from the exhuast when it was on the test
| | #15 | ||
| mad bad and very very old | Re: Failed My Mot :( :( :( But your exhaust had a leak, acoording to your first post. Cheers D
| | Scorg | Bravo / Brava | 10 | 04-08-2006 09:13 |
| | pranksta | Cinquecento / Seicento | 7 | 18-05-2006 11:03 |
| | GhostWKD | Cinquecento / Seicento | 7 | 12-01-2006 00:43 |
| | mdsremos | Cinquecento / Seicento | 15 | 25-06-2004 22:10 |
