The mpi sei pump is in the tank and also contains a filter and regulator (3 bar).
As you will have an external regulator and return rail (the mpi sei doesn't have or need this) and an external in line filter, I don't think it makes any sense to use the mpi one imho.
Use one of the others
Kristian
Not 100% accurate, the pump on the Sei MPi is fitted in a system that is return less and therefore its controlled by the ECU, it regulates the flow/pressure by what is needed on the car, though sure you know this.
There is no such thing as a "3bar" fuel pump as the pumps are measured by how much fuel they flow at a certain level. The pressure is set by the regulator, in the Cinqs case this is anywhere between 0.8-1.2bar standard, so a fairly large bracket they fall into. Most in tank pumps on standard road cars run at 3bar as this is what fuel injectors are measured at, but of course extra pressure can be applied, most pumps will flow to 5 bar.
I would recommend that if a 2nd injector system is used on a turbo charged car, then set the original regulator at minimum 1.2bar or can be raised to 1.4bar (turn alley bolt clockwise to increase pressure0, and then set the 2nd injector to 3bar, though remember if using a rising rate regulator to set with the vacuum pipe disconnected, you will then see about 2.5bar on idle with it rising in proportion to how much boost is being felt by vacuum connection on top of reg which raises pressure accordingly. If running two regs you have to have the injector's plumbed in series not parallel otherwise fuel will only be set by the lowest regulator.
I am sure it has been worked out that if running only the single injector on these cars roughly 80bhp is maximum car can be run as this means the injector is running at close on 100% duty cycle, though I only read that on here never actually worked it out myself. Of course ensuring you are running more pressure will make it run that little bit higher bhp.
Lastly, I would not run the standard injector at much above 1.4bar as it could then end up over fuelling the car and leading to bore wash.
Mine looked like this.
