| Just brought a Cento! Just brought a 98 Cento for my girlfriend to learn to drive in. 56k miles, last serviced at 50k miles in Dec 05. I am wanting to do a DIY service on the drive. Change oil, filter, air filter and generally check of fluids. Anything else I should change or check? Thanks.
| Ah. Not good... | Re: Just brought a Cento! Change the plugs. If there's no evidence of a recent cam belt change (if you have a Sporting) then I would do it for piece of mind, althought the FIRE engines are 'safe' engines, i.e. the valves won't hit the block if the belt goes. If the handbrake works and the clutch is good, with no clonking from the rear suspension, then you should be OK ![]() | ||
| | #3 | ||
__________________ Current: '99 Sei S - 15" TD Alloys, Custom Chrome Racing Exhaust, All-round Tints '84 Mini 25 - Limited Edition With Webasto Sunroof '86 Mini City | |||
| | #4 | ||
| custodian of imola blue | Re: Just brought a Cento! Change the handbrake? Noway! If it ain't working it's usually an easy DIY job (albeit a bit fiddly and messy). (See the guide.) I'd check the pads, shoes and disks for wear. Again, easy DIY and not expensive.
| | #5 | ||
| Re: Just brought a Cento! My handbrake was adjusted 5 times to try and get it to work Maybe mine's just naff! ![]()
| | #6 | ||
| ow! pinched my eyeball! | Re: Just brought a Cento! depends what exactly we are talking about in 'change the handbrake'?
__________________ removed so the flufftards can dry their eyes ![]() Want +20BHP for £2? do not click this link!!!! | ||
| | #7 | ||
| meow | Re: Just brought a Cento!
__________________ ![]() 1993 Uno Turbo / 1995 Punto 55 / 2000 Punto jtd | ||
| | #8 | ||
| FFFTW! | Re: Just brought a Cento! Check the oil breather and throttle body breather pipe thingy to make sure there actuall connected to the filter box... mine wasn't and i only realised like a week ago after owning the car about 2 months... go knows how much crap theyve sucked in ![]() oh and check the condition of the clutch cable... common failing point. you dont wanna be stuck at the side of the road cos its worn and snapped
__________________ If my post has helped you, please click the Thanks button ![]() | ||
| | #9 | ||
| Clubcento Member | Re: Just brought a Cento! Why do people keep forgetting the fuel filter? Would add one of those to your service parts list also.
__________________ Disclaimer: I reserve the right to an opinion, no animals have been harmed during this opinion . | ||
| | #10 | ||
| | #11 | ||
| Re: Just brought a Cento! We are actually getting the knocking from the rear (suspected it was the exhaust) but reading the forum makes me think it is bushes. To be honest, not sure if I'll bother changing these as this car really only has to last the learning process and then sell it on for whatever we can get. Anything bad going to happy (except knocking) if we dont do the bushes?
| | #12 | |||
| mad bad and very very old | Re: Just brought a Cento!
Cheers D
__________________ If it has pistons or tits, its going to be expensive. | |||
| The Return of the Cento | Steven | Cinquecento / Seicento | 24 | 11-10-2007 02:50 |
| For Sale: Free Parts Mainly Punto, Cento, Uno (Miscellaneous) | gaz.d | For Sale / Wanted | 0 | 22-10-2006 10:22 |
| Cento plans? | chrisxn | Bodyshop | 2 | 18-10-2006 13:17 |
| cento oil pressure sender on 1242 | arc | Cinq/Sei > Technical | 6 | 10-12-2005 15:02 |
| Cento gear lever | king jay | Cinq/Sei > Technical | 4 | 22-01-2005 12:07 |
