| FF Party Animal | bare metal! is there a certain way that i would have to screw into the bare metal of the doors at the bottom by the door pockets. other screws seem to go into a plastic thing set into the door. are these neccesary? [}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)]Little Red Devil (L.R.D)[}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)][}:)]
| if you get a tap and dye set the sme size as your screw you can make it have a thread so it will hold well in the metal, if not then just use self tappers, as they widen and should hold. good luck madcar :D:D:D
| | #3 | ||
| mad bad and very very old | The theory behind the ickle plastic things is that they go into a prefinished hole that has paint all around. The screw goes into the plastic so no screw/metal interface. Self tapping screws, by their very name mangle the metal to suit their own thread, thereby breaking the zinc coating allowing steel/ steel interface and therefore, oxidation. Or bloody rust. Cheers D Grumpy old git going fast downhill rather than downhill fast!!
| | #4 | ||
| and you don't want that! 99 Brava 100 HSX,Met Cognac 04 Toyota Avensis 2.0 d4d. Champagne. 16" Alloys, Climate, Traction Etc....
| | #5 | ||
| well thats all id do to fix it then wack a bit of paint on them to stop oxidisation or rust :D
| Bare paint on door runners | Stu DemonD | Ulysse | 12 | 30-10-2004 22:22 |
| | Lemzip | Punto | 4 | 31-07-2004 03:23 |
| Filling up at bare minimum | ts86net | Lets Talk FIAT | 17 | 30-03-2004 05:34 |
| | Sando | Cinquecento / Seicento | 3 | 04-12-2003 22:07 |
