right then.while at 1st the 6 speed from a punto 55 seems a great upgrade there are a few issues.
the main stumbleing block is actually finding one as these are very hard to come by 2nd hand.
the next thing is the 6 speed 'box is slightly longer than the 5 speed box so you will get some rubbing on the end of the 'box at full lock.
its not a straight fit either.you will need to transfer over the cinq selector mechanism.
what you need to be aware is the difference in ratios.the 6th gear is actually lower than a cinqs fifth gear so not really any god for top speeds nor motorway cruising.
a cinq on sporting alloys would do 93mph at 6000 revs in 6th
also a cinq speedo drive would give you a higher reading than actual speed.
novitec used to do taller 5th gear kits but these have been discontinued.
however the closer gears in a 6 speed will allow you to keep the car in the power band more,right up the gears.
now unfortunatly,later seis use a difference driveshaft set up so i cannot confirm whether or not they are a straight fit or not
heres a comparison of ratios on 3 punto models
thanks to pete(fixitagaintommorow) and stonenewt for the info
* Final drive is different depending on the wheels, the 13" models get a higher ratio FD to compensate for smaller rolling diameter55/60/75* 55 6sp Sporting 6sp
1st 3.909 3.545 3.909
2nd 2.157 2.157 2.158
3rd 1.480 1.480 1.480
4th 1.121 1.121 1.121
5th 0.902 0.902 0.921
6th N/A 0.744 0.766
F/D 3.563/ 4.923 4.071
3.733
