Published by levemircento 13-03-2007 | |||||||||
| The following 2 users say "Thank You!" to levemircento for this useful post: | ||
Chamelespoon (05-08-2008), Smiler121 (08-02-2009) | ||
| | Re: Cinquecento rear hub/bearing replacement NO EDIT BUTTON!! ? You granny could do this job, but cracking the hub nut loose might give her a hernia!!
__________________ | ||
| | Re: Cinquecento rear hub/bearing replacement if you need to edit,pm me the details and i will edit accordingly
__________________ need to contact a mod? click me _need to contact admin? click me_FAQ's_ Guides_events Want +20BHP for £2? ______ Downloads ![]() | ||
| | #3 | ||
Posts: 45 Thanks: 0 Trader Rating: 0 | Re: Cinquecento rear hub/bearing replacement i need to change the back plate on mine but i cant get the soddin 30 mm nut off i hav jumped on it and everthin with a bar i done one side but the other side dont seem to wna turn any ideas??? thanx
| | #4 | |||
use a long bar [something like a 4 foot length of scaffold] over a 1/2" drive socket [or bigger] and suitable T bar, undo in the normal direction, it will come undone!
__________________ | |||
| The following user says "Thank You!" to levemircento for this useful post: | ||
| | #5 | ||
Posts: 3,763 Thanks: 131 Trader Rating: 2 | Re: Cinquecento rear hub/bearing replacement hmm ... have the car on the road, put the 30 mm socket in and a breaker bar, and just stand on it for like 10 - 20 seconds, then the hub nut will be lose, no long bar needed no nothing. Remeber just stand on it, don't bounce about, let me come losse naturally. Just recently done this , because i needed to take my rear trail arm out ![]() Ming
__________________ Wanted : Nothing at the moment Last edited by ycming; 10-04-2008 at 12:00. | ||
| | #6 | ||
| | Guide doesn't mention using grease?
__________________ That which does not kill us makes us stronger!!! | ||
| | #7 | ||
| | #8 | ||
| | Re: Cinquecento rear hub/bearing replacement Wheres the cheapest place people have come across for replacements?
__________________ uʍop ǝpısdn sı ɹǝʇndɯoɔ ɹnoʎ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı | ||
| | #9 | ||
| | Re: Cinquecento rear hub/bearing replacement Your local motor factors will either have them, or be able to obtain them for a good price. I got mine from Andrew Page LTD which are a large factors in the north west, I think I paid £18 ish You can get them off ebay, but when you add in the postage it might not appear as good a bargain.
| | #10 | ||
Posts: 31 Thanks: 0 Trader Rating: 0 | Re: Cinquecento rear hub/bearing replacement
| | #11 | ||
| | Re: Cinquecento rear hub/bearing replacement hi,this bit just caught my eye whilst searching some advice via the web "Refit new hub to stub axle, replace the large washer, I had to reuse the old nut - which upon inspection was sound, due to the new nut having too large a thread" i've read a few different places that the nut should be replaced by a new one or your wheel "WILL" fall off !!,it sounds stupid as there's no retaining device on the nut or the stub axle,does anyone know how true this is as i removed the hubs regreased and replaced them after having a rumbling from the rear and i didn't replace the nuts,now everytime i drive it i'm half expecting my wheel to overtake me and i can only find them for sale as part of the kit which i don't need the whole lot it'd be an expensive nutby the way great forum
| | #12 | ||
| | Re: Cinquecento rear hub/bearing replacement The torque that the nut is tightened to, is so huge that the chances of the nut failing in operation is slim [or, it coming loose], if the nut does fail it will probably do so when tightened, either due to a worn thread, or fracture of the nut itself. I would always recommend a new nut is used, however in my case on the above project I trust my own judgement and my own work if deciding to reuse an existing nut.
__________________ Last edited by levemircento; 24-11-2008 at 18:54. | ||
| | #13 | |||||
thanx for the prompt reply ![]() so could you share you knowledge with me?would i be right in saying if there was no sign of a fracture and the nut was done to the correct torque then it would be perfectly safe to use the old one,i've done other cars over the years and the ones i've done they've normally got a castle nut or the key in the shaft to enable you to tap the head of the nut into the key to stop it undoing,it's just i've never come across such hub nut with no way of ensuring it don't come undone thanx in advance
| | #14 | ||
| | Re: Cinquecento rear hub/bearing replacement What I am saying is, yes, I reused my existing nut, as I was happy to do so given its condition and was satisfied that it tightened up ok. In your situation, if you are not happy that you reused the nut, and think the wheel is going to come off, then stop driving the car and get a new nut, I cant say if its right or not for you - thats a decision you have to make. You should be able to buy the nut on its own from Fiat. If somebody brought a car to me, to replace a hub, then a new nut would be fitted and tightened to correct torque.
| Currently Active Users Viewing This Article: 1 (0 members and 1 guests) | |
| Article Tools | Search this Article |
| Article | Article Starter | Category | Comments | Last Post |
| Replacement rear towing eye cover | Bootle | Panda | 1 | 28-02-2007 17:25 |
| | Darkartist | Cinquecento / Seicento | 4 | 10-04-2006 00:47 |
