| How to remove and refit rear hub/bearing assembly Takes about 30mins, you will need a good jack, wheelbrace, breaker bar with 30mm socket, 12mm spanner, mug of tea. No swear words needed for this job, its simple!! Oh yes, a new bearing/hub assembly!!! [if you are replacing] ... | ||
| | #15 | |||||
| | Re: Cinquecento rear hub/bearing replacement
as for someone elses car then i totally agree with your judgement there,thanx for the time you've taken to reply
| | #16 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | Re: Cinquecento rear hub/bearing replacement How do I check to find out if they need replacing, the sound, the wheels wiggle, the wheels fly off, or all of the above or something else?
| | #17 | ||
| | Re: Cinquecento rear hub/bearing replacement this is my summary of your question a failed bearing may make a deep humming/rumbling sound while you are driving along, the noise will vary with speed or, it could have play in it, ie, be loose, jack up the wheel in question and grab each side of the tyre, either at 12 and 6 o clock, or 6 and 9 o clock positions, and try to wobble the wheel, if there is play you will feel it I doubt things will get that bad that it will make the wheel fall off, dont think thats possible at all
__________________ | ||
| | #18 | |||
never underestimate the importance of getting them fixed
__________________ need to contact a mod? click me _need to contact admin? click me_FAQ's_ Guides_events Want +20BHP for £2? ______ Downloads ![]() | |||
| Currently Active Users Viewing This Article: 1 (0 members and 1 guests) | |
| Article Tools | Search this Article |
| Article | Article Starter | Category | Comments | Last Post |
| Replacement rear towing eye cover | Bootle | Panda | 1 | 28-02-2007 17:25 |
| | Darkartist | Cinquecento / Seicento | 4 | 10-04-2006 00:47 |
