Comment
Guide Tools
<!-- google_ad_section_start -->Remove & Refit steering column stalks<!-- google_ad_section_end -->
Published by levemircento
13-08-2012
Difficulty Level: 2
User Rated:Unrated
Lightbulb Remove & Refit steering column stalks
Remove and refit steering column stalks
I had to carry out this job as the headlamp flash wasnt working on my headlight stalk, as I do a lot of motorway miles its important to me, the car has recently had an mot, I told them about it but they said that they dont test the flash function just the high beam, and its warning light, which was ok on my car, the flash function has steadily got worse over the last couple of months and then stopped working altogether.
Its quite an easy job
Tools required
flat and philips screwdrivers
24mm socket and torque wrench for s/wheel nut [50Nm]
8mm spanner
hammer
1 hour of time
You perhaps should disconnect the battery for this, but I didnt, I just disconnected the horn at its connector in the engine bay, otherwise it will be going off all the time when trying to remove and refit the horn push
This is what we are removing and refitting:
Ok, set your steering straight and be happy that the steering wheel position is ok.
Lever off the steering wheel centre/horn push with a flat blade screwdriver, theres 3 clips that hold it in place
Remove the two springs, and undo the nut holding the steering wheel, I used a torque wrench for leverage but it came off really easy, unscrew the nut to the end of the thread, then tap the nut/centre column with a hammer and this will shock the steering wheel free, remove the nut and washer and pull off the steering wheel, a little wiggle and pull up, not too much force or it might hit you in the face.
Make a note of the position of the "hole" in the indicator cancel ring for refitting
Undo the column covers, 3 screws underneath, then seperate the two halves to reveal the wiring etc
Pull out the wiring plugs from the dash
And undo them, you dont need to make a note how they go, each one is unique so you cant get them the wrong way putting them back
Now to undo the stalks, undo the 8mm bolt which clamps the stalks to the column, then pull them up over and off the top of the column
At this point, I thought I would check the tightness of the main column bolts, seeing as they are accessible, I just nipped them up slightly tighter.
Now to refit
Slide the new[er] stalks over the column, slide them down all the way, theres no locating fittings that keep the stalks from turning left to right so I put the top cowling in place to get a good position then tightened the 8mm bolt
Now set the indicator cancel ring
Reconnect the wiring
Push wiring back into the dash
At this point I thought I would have a test, flick the ignition on, pull the flash stalk, YES, it worky!
Refit the bottom cowling around the column
Carefully refit the steering wheel making sure that the nipple behind it fits into the cancel ring
Refit the washer and nut, tighten to 50NM - or TIGHT if you dont have a torque wrench, I held the steering wheel with one had and tightened to 50NM with the other with ease
Refit the horn push springs
Locate the 3 tabs on the back of the horn push, and snap it back into place on the steering wheel
JOB DONE
[of course I then reconnected the horn wire, then fully tested all stalk functions, and horn]
Thanks for reading, any questions? fire away..
Likes yellowbrick liked this post
Old 03-12-2012   #1
Re: Remove & Refit steering column stalks
Great, this will come in handy as the "better" half snapped my Cinqs wiper stalk, and with the Snowdonian weather.........not good!
found a new set of stalks for 15 on ebay, so onward and upward. Cheers.
alfagog is offline Reply With Quote Quote
Old 2 Weeks Ago   #2
Portugal
great! just looking up how to do this as Ive got the problem with high beam works at the wrong 2/3rds position and the stalk does not stay there!
yellowbrick is offline Reply With Quote Quote
Old 2 Weeks Ago   #3
Portugal
question. What colour is the headlight high beam wire?
how did you go about fixing it and also, do you have any tips for high beam malfunction how to fix it!?
Comment
Guide Tools
(T) Steering Column Stalks / Headlights desert rat Barchetta 4 21-02-2010 23:11
(T) how do i remove/refit starter motor loops84 Punto (Mk2/2b) 3 25-05-2007 17:18
(G) Steering column stalks funkycinq Cinquecento / Seicento 2 17-12-2005 13:27
