Comment
Guide Tools
<!-- google_ad_section_start -->Fuel Filter remove and replace<!-- google_ad_section_end -->
cinquecento sporting
Published by levemircento
16-03-2011
Unrated
User Rated:Unrated
Thumbs up Fuel Filter remove and replace
Fit a new fuel filter cinquecento sporting
may apply to the 899 too
Tools Required
two jacks + axle stands, or car ramps
10mm socket and ratchet
side cutters
pliers
screwdriver
New filter
two new clips [14mm]
Here we go then, to replace the fuel filter on a cinquecento sporting, you will of course need a new filter, buy this from ebay or your local motor factor, it would be best to buy two new clips too just in case the old ones are no good for re-use, knowing a bit about cars in general I didnt buy a filter specific to the cinq, instead I bought the cheapest metal bodied fuel injection filter I could find at about the right size, only cost me £3 including postage £ker ching!!, we will look at that later.
First off, you need to be able to have good access underneath the middle of the car, do this via ramps, or jack the car up, I used two jacks and jacked up one side, now I fully trust my jacks, and I wasnt going to be pushing or pulling anything underneath which would potentially make the car fall on me, however the sensible thing to do would be to use axle stands and dont go underneath until you are sure its safe to do so
ID:	88117 Click image for larger version
Here we have the fuel filter, its on the drivers side of the tunnel next to the exhaust expansion box, the filter has two small flexible fuel pipes fitted to it
ID:	88119 Click image for larger version
Using a 10mm socket, undo the bolt located at the very top which holds the metal clamp around the filter, this is fiddly to get to and this is where a good amount of access underneath really helps, fully remove the bolt
Pull the metal bracket from around the filter, it just bends out of the way, dont lose the rubber sleeve
Next, remove the clips holding the flexible fuel pipes to the filter, you can twist a small screwdriver in them to break them, you may have jubilee clips, if so then just undo them, be prepared for the screws to either break, or the clip to be rusted, pull the pipes off the filter and be ready for some petrol leakage
With the filter removed, compare it to the new one, my "lucky dip" find off ebay was just the same, except slightly longer on the inlet and outlet pipes, spot on that'll do for me.
Fit the new clips to the two rubber fuel pipes, then fit the filter back to the car noting the fuel flow arrows, the arrow must point forwards to the front of the car, this is the direction of the fuel flow, important.
Now wrap the metal bracket round the filter with its rubber sleeve between the bracket and filter, the next part iss REALLY fiddly, getting the bolt back into the hole - just in case you want to change the filter again at some point, put some copper grease on the thread to stop it siezing, when done, tighten up and adjust the filter position before making the bolt fully tight
all done, it is recommended to run the engine for a few mins to check for leaks, note that after startup the engine might stall until the fuel comes through properly.
conclusion
I have owned the car since december 06, and have not previously changed the fuel filter, in the latter half of 09 I had a rusted fuel tank, I replaced the tank but still did not replace the filter [I probably forgot, but there was bound to be rust debris in it], quite recently the car would stutter slightly under power especially if the revs were down low, or I changed up too soon, out on the road for a 15 mile drive after replacing the filter it felt like the stutter had gone, and overall there was a feeling that the engine was smoother in its running.
Thanks for looking.
Thanks jMz, adr1ean, ValleyBoy05, MadMan0, kritip and 1 others thanked for this post
Likes BUNDEVSKI, jMz liked this post
Old 02-04-2011   #1
kritip's Avatar
Trader Rating: 4
kritip has donated!
Re: Fuel Filter remove and replace
Got myself one to do. How much fuel leaked out and did you do it with a pretty empty tank?
You can reuse the original clips if you have the right tool rather than breaking them
kritip is offline Reply With Quote Quote
Old 03-04-2011   #2
Get a wriggle on!
levemircento's Avatar
levemircento has donated!
Quote Originally Posted by kritip View Post
not much fuel came out, I popped a bolt in to plug the pipe from the tank while i sorted the filter onto the front pipe, then swiftly removed bolt then put filter into the rear pipe
regarding clips, I already had two new ones which were proper petrol pipe clips with screw fixing
must be time for a brew
levemircento is offline Reply With Quote Quote
Old 22-01-2012   #3
France
I've just changed the filter on my R-reg car, at 89k miles. It was the original filter... (original FIAT hose clips give it away). The filter clip had no rubber cushion (and there wasn't sufficient clearance for one between the clip and the filter), but the old filter had a strip of thin clear plastic shrunk onto the periphery, to do the same job of chafing-avoidance I suppose.
I bought some new hose clips off eBay. Both 14/16mm and 13/15mm dia fit fine.
Your guide was very helpful for preparation, thank you.
Likes TakeTheMikey liked this post
manxfrance is offline Reply With Quote Quote
Old 22-10-2012   #4
Is it the same for sei, do you know? thanks muchly
OG Burrows is offline Reply With Quote Quote
Old 22-10-2012   #5
Get a wriggle on!
I dont know tbh, cant see it being much different, unless is an mpi car - that might be different to spi
Old 27-10-2012   #6
sei has different clips on it, they have button things on the side, I pushed them in with mole grips they just levered it off. Snapped both the bolts on the mount as well, so it's tie wraps at the moment.
bungler is offline Reply With Quote Quote
Comment
Guide Tools
(T) how to replace the fuel filter element on a 2007 ducato 2.2 appleyard Ducato 1 19-05-2010 22:32
(T) Doblo 1.3d multijet cargo fuel filter replace Pinta Doblo 0 04-01-2009 11:50
(G) Remove/Replace Sterring Wheel fiat_fandango Punto (Mk2/2b) 4 25-05-2008 10:41
(T) fuel and filter replace WINDMASTER X1/9 1 24-03-2007 21:37
(T) I cant remove the fuel filter!!!help jami Punto (Mk2/2b) 4 23-09-2006 03:26
