The FIAT Forum
Go Back   The FIAT Forum > Guides > Cinquecento / Seicento Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->SPI throttle body -- where the pipes go<!-- google_ad_section_end -->
Published by fingers99
13-05-2008
From the Italian Cinq manual, but with an English legend.
1. Fuel return to tank
2. Fuel pressure regulator
3. Air Inlet Temperature (AIT) Sensor
4. Injector
5. Mating surface
6. Fuel intake for throttle body
7. Hot water feed (from coolant reservoir)
8. Feed from charcoal cannister (EVAP)(blue)
9. Breather take off (brown) from cam cover
10. Manifold Absolute Pressure (MAP) Sensor take off
11. Throttle body
12. Throttle Position Sensor (TPS)
13. Idle step motor (sometimes ICV or IAC)
On some cars the Feed from charcoal cannister (EVAP) and Breather take off from cam cover seem to have been marked blue and brown respectively, but this may not apply to all cars.
Thanks to Kristian (kritip) for editing and acronyms.
Article Tools
The following user says "Thank You!" to fingers99 for this useful post:
custard (15-05-2008)
Old 15-05-2008
ow! pinched my eyeball!
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: SPI throttle body -- where the pipes go
image edited,only attached images in the guides section
removed so the flufftards can dry their eyes
Want +20BHP for £2?
do not click this link!!!!
custard is offline
Old 16-05-2008
Trader Rating: (0)
hi, the brown and black ended pipes from throttle body, where do they go on the air filter thermostat. looking into the engine is the brown connector to the left or right connection? info would be appreciated
mozzy is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
Removing coolant pipes from Throttle Body andyr Punto > Technical 1 15-08-2006 20:16
For Sale: Enlarged throttle body for spi (Tuning) punto_lad For Sale / Wanted 0 09-07-2006 12:07
Spare throttle body anyone (SPI Cento) Randomman Auction Watch 2 09-09-2005 07:46
Cinq SPI Throttle Body, 30mm. peaster2k Auction Watch 0 15-03-2005 17:55
(SPI) IE throttle body?? (AND POWER BOOST VALVES) uno70 Uno > Technical 3 17-02-2005 10:02
