| Removal and refitting of 1108 cylinder head Tools needed: variety of spanners from 10-16mm Ratchet and socket set, slimline 13mm socket for centre front head bolt 5mm allen key sump plug sharp knife Torque... | ||
| | #15 | ||
| | Re: Cylinder Head Gasket remove and refit Torque figures stage 1. 30 newton metres stage 2. + 90 degrees stage 3. + 90 degrees in my pics, the 90deg torques are shown by marking the head bolts, you can see that they are moved from pointing toward the back of the engine, then to the right, then to the front as you complete each stage torque sequence 8 6 2 5 10 7 3 1 4 9 bolts 8 & 7 are the cam belt side of the engine
__________________ | ||
| | #16 | ||
| | Re: Cylinder Head Gasket remove and refit i used the guide today and it was very good thanks. the following might help anybody who is taking head off. when i jacked the car up i took front bumper off as well (only 8 screws) this makes it much easier to get at radiator pipes. then when you remove exhaust manifold just unclip radiator and you can get rachet and socket on nuts. thanks again mick
| | #17 | ||
Posts: 18 Thanks: 0 Trader Rating: 0 | Re: Cylinder Head Gasket remove and refit Hi there - I'm currently having a new cylinder head gasket fitted to my '97 Cinquecento Sporting. What do you recommend I check that the garage has done in order to have effected a proper repair? What parts/procedures are essential? Cylinder head apparently OK, they say - was pressure tested and re-skimmed earlier this week.
| | #18 | ||
| | Re: Cylinder Head Gasket remove and refit they need to show you the old gasket and point out where it failed, and why it failed if the head was pressure tested and skimmed thats great, its a good idea to possibly have the water pump and cam belt renewed at this time, even a new thermostat too - somewhere along the line a part of the cooling system has failed, and this is why the head gasket has gone a check needs to be made that the radiator fan will come on when the engine gets hot chances are they will have bought a head gasket kit, this means you will have new gaskets on the inlet manifold, exhaust manifold, thermostat, cam cover and rubber O ring in the coil pack bracket, also new head bolts
| Currently Active Users Viewing This Article: 1 (0 members and 1 guests) | |
| Article Tools | Search this Article |
| Article | Article Starter | Category | Comments | Last Post |
| | circolo | Uno | 1 | 01-06-2007 17:06 |
