The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > Guides > Cinquecento / Seicento Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Remove and Refit Front Brake Pads<!-- google_ad_section_end -->
easy peasy this!!
Published by levemircento
26-02-2008
This has got to be one of the easiest jobs ever, whatever you do dont go to a garage or fast fit place as you will save ££sss doing it yourself, buy your pads from a local car shop/motor factors, its soo easy - your gran could even do it!!
Tools Needed
Jack and Wheel Brace
Axle Stand
Small hammer
Small pliers / or long nose
G Clamp
New Pads
Time
Beginner 40mins
Righto, we will deal with just one wheel, both are the same.
First, Handbrake on, and loosen the wheel bolts, jack up the corner of the car, I used a trolley jack under the front sill area, for safety's sake, use an axle stand to rest the car on, I didnt, but thats because I trust my jack fully!!
Remove the wheel
It helps if you turn the steering so the caliper is more accessible
Here we have the caliper, complete with old pads inside,
Look at the bottom of the caliper and you will see a pin, with a very small clip going through it:
Using a pair of pliers, carefully pull the clip out from the pin, careful as you dont want it flying over next doors fence, you will need to re-use it. The Clip:
Gently tap the pin with the hammer, go easy as you dont want the end of the pin to 'mushroom' as it might not come out, take your time, it will pop out quite easy after a few taps. When its part way out, wiggle it out the rest of the way with your pliers. The Pin & Clip:
Now, pull the caliper upwards, this will reveal the old brake pads, simply pull them out, and replace with your new ones.
Keep the caliper up, get an old brake pad and cover the piston in the caliper, arrange the G Clamp so it clamps the pad to the caliper, and turn the clamp gently to push the piston back in, you should not need much pressure, and you will know when it wont go any further. G Clamp and Caliper with old pad:
The new pads in place, make sure the pad material is against the disc, easy mistake to make, check and double check!!
Close the caliper back towards the hub, give it a push as you put the pin back in from behind, you can carefully tap the pin back into place, replace the small clip into the pin
That. is it!!
Refit the wheel, and repeat other side of the car. When both sets of pads are fitted, press your brake pedal a couple of times to get the pistons back to the pads, you will notice the first press of the pedal will probably go right down to the floor, then the second pump will be firmer.
Test the brakes at walking speed before driving off at speed, it will take quite a few miles for your new pads to 'bed in', after which you may notice they feel sharper.
This really is an easy job, using very basic tools, and a short amount of time, when working with brakes take all the usual safety precautions, check, and check again that the components are in place and fitted properly.
Thankyou, and good afternoon!!
Nik
Article Tools
The following 4 users say "Thank You!" to levemircento for this useful post:
BumbleBee (23-09-2008), custard (26-02-2008), nmrmak (28-05-2009), roudard (18-05-2009)
Old 29-02-2008   #1
Get a wriggle on!
levemircento's Avatar
levemircento has donated!
Re: Remove and Refit Front Brake Pads
Thanks Custard
a way to stop this would be to use a suitable drift of about 4mm diameter
levemircento is offline
Old 21-07-2008   #2
many thanks for the information.
did my front brake pads inside an hour for just £15.
it really is so easy.
One seicento schumacher special back on the road.
martyn 1108 is offline
Old 23-09-2008   #3
Got Fiat?
BumbleBee's Avatar
BumbleBee has donated!
I work with bikes allot and its esentially the same thing. Thanks allot for reassuring me and everyone else that wasn't entirely sure.
- Broom Yellow Cinq, Custom Exhaust, Ram air induction kit, Super 4 Sparks. -
Having ingested all of the data to hand I have only one conclusion:
You are a total plank
BumbleBee is offline
Old 18-05-2009   #4
Easiest job ever ... thanks to your guide ...
roudard is offline
Old 18-05-2009   #5
Get a wriggle on!
thanks for the thanks!!
I wonder how much kwik fit charge for a job like that
Of all the cars i have owned over the years, the pads on the cinq are the easiest ever to change!! thanks fiat!
Old 21-05-2009   #6
Used this guide a few months ago, was easy !!
Nice Guide, Thanks
P.s could put something in about Brake fluid cap needing to be removed + Copper grease is a great extra i fitted mine with grease to start with, few days later the squeeling noises was driving me crazy so removed pads greased them up pop them back in and now they are perfect :P
Zak1991 is offline
Old 4 Weeks Ago   #7
Smile Re: Remove and Refit Front Brake Pads
thankyou ur help guide was great, plus i saved my self over 120 quid, got all the parts of that well known auction site lol, did all 4 wheels new drums and hubs on rear and disks on front, all for 65 quid, and with the the other guides on this site done all with in 2 hours, meny thanks
kmbutt is offline
Old 13 Hours Ago   #8
Thanks did this today
Fiat Seicento 2002
If in doubt flat out!
Fiatseicento2002 is offline
The following user says "Thank You!" to Fiatseicento2002 for this useful post:
levemircento (13 Hours Ago)
Old 13 Hours Ago   #9
Get a wriggle on!
thanks for leaving feedback
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
(T) A handbrake which works! (Guide) circolo Uno 1 01-06-2007 17:06
(T) Front brakes, clutch pedal and carburettor. Lifesigns Uno 6 20-04-2007 17:30
Copyright ©2002 - 2010 FIAT Forum
