The FIAT Forum
Go Back   The FIAT Forum > Guides > Cinquecento / Seicento Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->HOW TO: Change a clutch on a cinquecento sporting 1.1 OHC engine<!-- google_ad_section_end -->
Clutch plate, pressure plate and thrust bearing.
Published by Tabblink182
17-02-2008
Wink HOW TO: Change a clutch on a cinquecento sporting 1.1 OHC engine
Before you start make no mistake, for someone with little or no experience like myself, this is no walk in the park. Although others on here may think different
First things first you’ll need to jack your car up at the front end. Be sure to use the suitable jacking point under the car just behind the front wheel. Place axel stands underneath the car also in a suitable position and check that the car is steady. Never ever work under a car only supported by a jack!
Okay before you start anything, you will need two main things to hand…
Lots of these
And these XD
Before you start any work it is wise to store all nuts and bolts accordingly in categories to avoid misplacement and confusion of what goes where! Here’s my little idea =]
Okay, you will need to remove the passenger side front wheel and disconnect the two big bolts that hold the bottom of the shock absorber to the hub assembly. (Note it may be easier to remove the steering rack joint onto the hub also, but as mine was solid, I didn’t try too much!)
On the right side of the diff (as your facing the front of the car) remove the driveshaft gaiter clip and the drive shaft should simply slide out of the inner CV joint. Be sure to wrap the tripod bearing with some sort of protection against grit and dirt. A Tesco’s bag should do =]
Next job is to secure the driveshaft away from the engine bay to stop the gearbox fouling on it when you eventually take it out.
Inside the engine bay, looking down onto the gearbox, pop off the reverse gear linkage on the top of the gearbox.
And unplug the wiring at the front of the box
Next job is to disconnect another ball joint on the back of the Gearbox; this is the main gear linkage. BE SURE TO LEAVE THE GEARBOX IN NEUTRAL BEFORE DISSCONNECTING THIS.
Just to the left of the balljoint just disconnected, there is a bracket holding the cable in place. This is secured by three bolts… remove this and secure the gear linkage cable out harms way.
Not sure what this wire is, but in any case it’s also need removing. Just undo the small bolt and it should just pop off
Now it’s time to disconnect the clutch cable right at the front on the gearbox, this is secured by a big nut, and a locking nut.
You will need to also disconnect the Speedo cable at the back of the gearbox, between the gearbox and the bulkhead. It’s tricky and space is limited, I couldn’t even get a decent picture of it = [
Right, now that all of the ancillaries disconnected from the gearbox. You will need to place a jack, with a piece of wood underneath the gearbox to support the weight while we undo the mounts for the actual gearbox.
The next thing to go is the rear gearbox mount. There are two bolts holding it to the actual gearbox actual gearbox, disconnect these and store safely. There are two more bolts holding the bracket to the chassis, one is in plain sight, the other is up inside the hole on the mount. Don’t try to undo the big bolt (as I found out), it’s just spins the nut on top which is inaccessible.
There is one more mount at the front of the gearbox which is held on by two bolts, undo these and store safely, there is no need to disconnect the mount from the actual chassis.
Now that basically the gearbox disconnected from everything, except the actual engine of course. Ensure your jack is properly supporting the gearbox and lower it slightly so that the whole right hand side of the engine drops along with the gearbox. It may also be necessary to support the bottom of the engine with another jack just to make sure the relationship between the engine and gearbox is plum. If it’s pissed, it will just jam on the splines and it will not come out. Whilst the engine is in this position, it gives better access to remove the starter motor, held on by three bolts…
You are now ready to undo all of the gearbox to bellhousing bolts, undo all of them except the upper most bolt, leave this on until last.
-STOP- And make a cup of tea
Once you are sure the all of the bolts are out (be sure to undo the nut on the stud bolt behind the starter motor as well. Then you can begin to pull the gearbox away from the engine. Shake it from side to side, up and down, they can be quite stiff. Once a gap is made between the engine and gearbox it is possible to get a long screwdriver, a crowbar, or prybars to gently pry the two apart while still pulling and shaking the gearbox.
With a little effort, the gearbox should dislodge from the clutch plate and hey presto, the gearbox is out.
-STOP- drink your tea, and have a fag =]
Now you have access to the clutch assembly, undo the six bolts that hold the plate onto the flywheel.
And the clutch plate and pressure plate should drop out.
Now, when you want to fit the new clutch assembly, you will need to align the clutch plate dead centre with the pressure plate. You can easily make a clutch alignment tool with a piece of wooden rod that fits closely inside the clutch plate hole. I found that a piece of 15mm copper tube worked perfect. Wind some insulation tape around the copper tube so that it fits tightly inside the pressure plate arms.
You can now offer up you new clutch, held together and in line using your home made alignment tool. Once it is in position and you are sure that it dead centre, you can tighten up all the bolts.
Changing the thrust bearing couldn’t be easier. Just pop the old one off, and slide the new one on. Be sure that it sits inside the fork properly; it will only fit in one way.
Now it’s time to refit the gearbox, get it up on the jack and offer it up to the engine. Be sure that the flywheel plate is sat on properly and with a bit of fiddling around, and with a lot of luck, it should slide into place.
You can the start putting bolts back into the bell housing.
Don’t forget that there is a bracket that sits behind the two uppermost bolts which hold the gear change cable bracket in position.
Attach the bottom flywheel cover
And all the gear linkage bracket back on
Reconnect the earth cable, both gear change ball joints, and the reverse linkage. And also the speedometer cable at the rear of the gearbox.
Connect the clutch cable back up and ensure its operation. There is also a guide here on how to adjust your clutch cable so I won’t go into it, but it does need doing!
Now you must jack up the engine and gearbox together so that they will line up ready to put the mounts back on. Reconnect both front and rear gearbox mounts.
the gearbox is now all in and you can slide the driveshafts back in, turn the steering wheel to the far left in order to put the driveshaft in on the driver’s side. Then do all the suspension bolts up before you move the steering again. And vice versa for the other side.
Put the wheels back on.
And lower the car off the axel stands.
Re connect the air box and any vacuum hoses you may have disconnected for better access.
And finally close the bonnet =]
Take it for a test drive, take it steady at first, if all seems okay, and then boot it. If anything sounds or feels weird/ not right, then come back and give everything a once over.
And that’s how you change a clutch. And I hope this helps someone, one day. XD
Article Tools
The following user says "Thank You!" to Tabblink182 for this useful post:
ChrisUK (18-03-2008)
Old 28-02-2008   #1
Get a wriggle on!
levemir's Avatar
Trader Rating: (0)
levemir has donated! United Kingdom
Re: HOW TO: Change a clutch on a cinquecento sporting 1.1 OHC engine
fantastic guide there
one thing that may be a tip, is the shaft that the thrust bearing slides on to, put some high temp grease on it, this will make the bearing slide much better giving in turn a smoother feel whel pressing the clutch pedal down
levemir is offline
Old 28-02-2008   #2
Trader Rating: (0)
Tabblink182 has donated! United Kingdom
nice tip
tried to edit, but cant ??????
Tabblink182 is offline
Old 08-03-2008   #3
Cinq Sp
Trader Rating: (0)
Vic20 has donated! United Kingdom
Thumbs up Re: HOW TO: Change a clutch on a cinquecento sporting 1.1 OHC engine
Brilliant Guide!
Couple of questions..
1 What do you do with the drivers side driveshaft? Do you just remove the boot gaiter clip and let the shaft slide out of the cv joint as the gearbox is removed?
2 Do the gearchange cables just pull off? what did you use to do this?
Vic
Vic20 is offline
Old 09-03-2008   #4
Trader Rating: (0)
Originally Posted by Vic20 View Post
Brilliant Guide!
Vic
1. yeh, i may have forgotten to add that bit in , but just undo the gaiter clip and the gearbox along with the cv joint will slide away from the driveshaft.
2. there is a bracket which guides one of the cables which is held on by three bolts. at the end of the cables there are balljoints, just lever these off with a screwdriver... they just pop off.
Old 12-03-2008   #5
Trader Rating: (0)
Is it the same on a Seicento Sporting only having just replaced clutch all seams ok but can not engage reverse gear ?????
Any ideas ???
Regards
Rob
robc is offline
Old 13-03-2008   #6
Trader Rating: (0)
it will either be a problem with you linkage, or the box itself.
check the linkages just under the gearstick aswell.
does it feel stiff moving to reverse and 5th? or does it feel okay but just wont go in ? or does it slide into reverse gear, and no drive ???
Old 13-03-2008   #7
Trader Rating: (0)
The gearstick goes into reverse position put is picking up forward drive to the wheels not reverse.
Regards
Rob
robc is offline
Old 13-03-2008   #8
Trader Rating: (0)
The linkage was fine before removing the clutch and didnt remove linkage from under the gearstick ?
Regards
Rob
robc is offline
Old 13-03-2008   #9
Trader Rating: (0)
this may sound silly (but i really have no other awnsers) there are two gear linkages.. you are sure you have them the right way round ??
tbh, you may be better off posting this in the cinquecento/seicento section, as youll have loads of people (who actually know what there talking about) helping you, instead of just me =]
Old 15-03-2008   #10
Get a wriggle on!
levemir's Avatar
Trader Rating: (0)
Just prior to removal of the gear link cables, dab some tipex onto one of them, and its operating lever on the gearbox, then you know when refitting what goes where.
levemir is offline
Old 15-03-2008   #11
Trader Rating: (0)
theoreticaly, it should be impossable to switch them over... one goes through a massive bracket.. which clearly bolts on the back.. hence that one being the back selector cable and not the reverse one at the front of the box.....
Old 20-03-2008   #12
Cinq Sp
Trader Rating: (0)
Unhappy Re: HOW TO: Change a clutch on a cinquecento sporting 1.1 OHC engine
I am in the middle of this job at the moment. All went well until trying to get the gearbox reconnected to the engine. It just won't go! was trying for four hours this afternoon and so far have not been able to get the spline to slide back into the clutch plate
I even used a proper alignment tool before refitting the pressure plate and clutch. Oh boy, is that gearbox heavy! my arms so ache tonight
Any tips on how I can get the damned thing back on? there is simply no play in the gearbox spline.
An interesting fault with the clutch that I have removed, the clutch was binding and there was judder. Two of the springs in the clutch plate had broken. I'll post up some pics when my arms dont ache so much!
Vic
Vic20 is offline
Old 20-03-2008   #13
Get a wriggle on!
levemir's Avatar
Trader Rating: (0)
Is the release bearing in the way/not fitted properly?
Think I will be getting my clutch next week, then plan for some dryer weather to sort it
levemir is offline
Old 21-03-2008   #14
Trader Rating: (0)
it is difficult to get it back on, support it on a jack, and try to slide it in.
and remember that it may not go in completly plum. you may have to twist it abit to get the splines to line up, and then once its on, twist it back to line up the holes for the bolts on the bellhousing.
funnily enough, it took me aq whole day to get the gearbox out.... and about 2 minutes to get it back in
lol
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
(G) how many cento owners custard Cinquecento / Seicento 70 3 Days Ago 21:05
