The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
FIAT Auto Specialist Team
Go Back   The FIAT Forum > Guides > Cinquecento / Seicento Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->cam belt change<!-- google_ad_section_end -->
cam belt change
changing the cam belt and tensioner on a cinq/sei
Published by custard
08-04-2007
preperation
1st of all get the car ready for the job in hand.
  • disconnect the battery
  • handbrake on
  • loosen the drivers wheel bolts,but DO NOT unbolt fully or remove
  • undo the 2 13mm mounting bolts on the expansion tank and lift it forward to the front of the engine bay.no need to remove the coolant hoses
  • if you want a bit more access you can remove the drivers side headlight as well.
  • there is 1 10mm on top and one 8mm to the rear of the headlight.then unplug the wiring connectors and indicator bulb holder
  • remove the electrical wiring for around the top cam belt cover.undo 1 10mm bolt for the top cam belt cover(to the left front of the engine) and remove the cover
  • jack the car up on the drivers side and put an axle stand underneath to support it.
  • (do not work on the car with just the jack supporting!!)
  • remove the drivers side wheel
  • remove the wheel arch liner and lower engine cover.these are held in with 8 & 10mm bolts/screws
Contents
Article Tools
<< <    Next Page: removing the belt (Page 1 of 4)    >  >>
Old 16-09-2008   #1
Re: cam belt change
I used this guide last weekend on my sei sporting , simple to follow and accurate.Thanks.
seicentom is offline
Old 10-10-2008   #2
now with added gold
custard's Avatar
Trader Rating: 1
custard has donated!
Re: cam belt change
good stuff,remember the guides are not set in stone
so if anyone has tips or better ways to do something then post it or pm me and i can edit
same goes if anyone has pics to add
need to contact a mod? click me _need to contact admin? click me_FAQ's_ Guides_events
Want +20BHP for £2? ______ Downloads
Originally Posted by Vimto Rolf View Post
well looks like ill always be single then
custard is offline
Old 11-01-2009   #3
Re: cam belt change
used this guide yesterday and it was a easy job
SRIDAVE is offline
Old 21-01-2009   #4
Re: cam belt change
Great guide...tnx
Menno86 is offline
Old 24-06-2009   #5
Get a wriggle on!
levemircento's Avatar
levemircento has donated!
Re: cam belt change
this might be useful here
levemircento is offline
The following user says "Thank You!" to levemircento for this useful post:
custard (24-06-2009)
Old 16-08-2009   #6
Re: cam belt change
Great description Custard thank you, is it not prudent to change the water pump as well while doing this job, as I didnt see it mentioned???FF
Fistral fig is offline
Old 16-08-2009   #7
now with added gold
custard's Avatar
Trader Rating: 1
Re: cam belt change
well its a safe engine so its less of an issue as on interference engines
however if you have it all stripped and have the cash then it doesnt hurt
custard is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
(T) Stilo Abarth Timing Belt Change johns Stilo 15 05-11-2006 14:56
(T) Cam Belt - When To Change MoDiFiEd Punto 13 20-06-2006 15:47
(G) cam belt change slacky1230 Stilo 6 17-04-2006 03:34
(T) 1.9 TD cam belt change cabs Tempra 4 13-02-2006 15:39
(T) cam belt change? collings Punto 1 24-06-2005 09:33
Copyright ©2002 - 2010 FIAT Forum
