The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Cinquecento / Seicento > Cinq/Sei > Technical
Old 21-06-2006   #1
rich_lufc's Avatar
Trader Rating: (0)
Engine swap
Hey all,
Just ordered my 1242 punto 75 engine! Wondering if I NEED some sort of trolly to remove the old engine and move the new one in place or if anyone can suggest a way around it?
Rich
rich_lufc is offline
Old 21-06-2006   #2
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
rallycinq has donated! New Caledonia
Re: Engine swap
I did a swap by lifting the car away from the engine rather than lift the engine into the car.
D
rallycinq is offline
Old 21-06-2006   #3
rich_lufc's Avatar
Trader Rating: (0)
Re: Engine swap
So I take it you removed the engine up out of the engine bay rather than droping it down.
Rich
Old 21-06-2006   #4
99sei's Avatar
Trader Rating: (1)
99sei has donated! United Kingdom
Re: Engine swap
sounds like rally cinq disconnect the engine and hoisted the car up so th engine came out easily.
best way is lifting the car up and placing it underneath and hoisting it from there (in my opinion)
Originally Posted by 99sei
im ginger and special
and now im terrorising the roads in my cinq
99sei is offline
Old 21-06-2006   #5
rallycinq's Avatar
Trader Rating: (1)
Re: Engine swap
No No, I supported the car on axle stands and undid all the ancilliaries. Once they were all off, I lowered the front of the car until the engine was resting on a small pallet on the ground.
I then undid the three mounting bolts and jacked up the body leaving the engine, and box, on the pallet. It was then simple to pull the pallet forward out of the way to split the donk 'n' box.
D
Old 21-06-2006   #6
rich_lufc's Avatar
Trader Rating: (0)
Re: Engine swap
Oh right. Ive decided to plonk it on a piece of plywood and drag it out. Simple enough.
Cheers for the advice!
Rich
Old 22-06-2006   #7
rallycinq's Avatar
Trader Rating: (1)
Re: Engine swap
I think you'll need to raise the sheet of wood off the ground to support the engine to allow enough slack to get the mounts undone.
D
Old 22-06-2006   #8
rich_lufc's Avatar
Trader Rating: (0)
Re: Engine swap
Ok cool. Think im borrowing an engine lift off a mate so problem could be sorted.
Rich
Old 22-06-2006   #9
99sei's Avatar
Trader Rating: (1)
Re: Engine swap
D
didnt i say that lol must be the way i explain things
engine hoist makes things easy, especially if it is a tripod one as you can lift the whole front end with it
let us know how you get on with it
99sei is offline
Old 22-06-2006   #10
rich_lufc's Avatar
Trader Rating: (0)
Re: Engine swap
Will do, engine should arrive tomorrow so hopefully ill have the car off the road by the weekend and I can get cracking with it straight away! No doubt ill get over enthusiastic and post tons of pictures each night!
P.S. expect multiple stupid questions comming your way when I get stuck!
vB code is On
1242 engine swap vandisian Cinq/Sei > Technical 25 13-06-2006 01:54
engine swap cost + clutch problem distortionrockets Uno > Technical 23 15-01-2006 17:31
Multipla engine swap... drnino Multipla 4 21-06-2005 06:53
Punto engine swap Cinq_Sport_BiG_DaVE Cinquecento / Seicento 3 24-09-2004 11:45
Anyone for a bonkers engine swap???? max Auction Watch 0 27-03-2004 00:32
