| Alloy wheel sizes Hi all, I know that this has been covered before but will 5.5X14 or 6X14 alloy wheels fit a sei that has been lowered 30mm and if so which tyre size am I best off opting for? Cheers Rich
| RIP L181 VBB | Re: Alloy wheel sizes IIRC 5.5 x 14 is what the sei abarth alloy is so yes that would fit. Your best doing a search
__________________ ![]() 2001 Modded Sei Sporting - GONE!! 1998 Ford Mondeo 1.8LX - P/X'ed 2002 02 Ford Focus 1.6 Zetec w/ Climate Pack! | ||
| | #3 | ||
| Re: Alloy wheel sizes Yeah cheers applesei. Any idea of the best tyre size when considering the car is lowered 30mm? Secondly will the 6X14s fit? Also I think there should be a sticky of a list of alloy and tyre sizes that will fit without rolling the arches in the frequently asked questions bit so no noobs like me need to keep asking the same questions over and over. Cheers Rich
| | #4 | |||
| ate too much | Re: Alloy wheel sizes
most of the time the answer wouldnt be there and to be blunt even if it was it would most likely be posted anyway
__________________ need to contact a mod? click me _need to contact admin? click me_FAQ's_ Guides_events ![]() Want +20BHP for £2? | |||
| | #5 | ||
| Re: Alloy wheel sizes Please please please can someone tell me if 6X14 will fit and what tyre size is best suited? Cheers in advance Rich
| | #6 | |||||
| | #7 | ||
| Drives A Red Cinq Abarth | Re: Alloy wheel sizes it depends on the ET etc, what stud spacing, eg 4x98 is fiat, but can fit 4x100 with wobbly bolts. ET is 25 iirc on cinqs/seis.iirc punto gt alloys are 6x14s and they fit so maybe yours will.. i have my car dropped 40mm with 175/50s on 5.5x14 wheels, and i know mase for example is 60mm drop with 6x14 wheels(GTs) with 175or185/50s on. the ET and stud pattern should be stamped on the wheels somewhere. HTH, someone correct me if im wrong.. Craig. btw all this info can be found by a search..
__________________ Sold Cinq Abarth Bought VanAakens Development Cinq Turbo Daily Driver: Helios Blue 89' VW Jetta Mk2: Coilovers and Ronal Turbo Alloys | ||
| | #8 | ||
| RIP L181 VBB | Re: Alloy wheel sizes post a pic of the wheels and what car they are from if they are second hand
| | #9 | ||
| Re: Alloy wheel sizes ok. It a choice of 3 due to the lack of 14" wheels on the market tho links to any decent sites would be appreciated. 1. 2. 3. (I prefer 2 and 3) Cheers Rich
| | #10 | ||
| ate too much | Re: Alloy wheel sizes these have a pcd of 114 like these dont see any info on these but i would go with the other ones from a style viewpoint
| | #11 | ||
| mad bad and very very old | Re: Alloy wheel sizes Number one is 4x114, so that will not fit. The other two are available in 4x98 so they will fit the hub. The offset is 35 so you would need a 5mm spacer to cope. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #12 | ||
| RIP L181 VBB | Re: Alloy wheel sizes I like the second ones, although 5 spoke ones looks sweet when on the move when you look in a shop window! hmmm ill still stick with the second ones seen as i have 5 spokes ![]()
| | #13 | ||
| hi friends :waves: | Re: Alloy wheel sizes Here is the issue really Rich, if say you run Abarth alloys with an offset of 36mm on the front you want to lose the spacer and run Fiat 10mm hubcentric spacers however this applies cos the width of the rim is 5.5inches with 6 inch width the wheel would stick out more so you have to adust the spacer size to compensate. Have a look at this and try and see if you get what I mean http://www.1010tires.com/WheelOffsetCalculator.asp Liam
__________________ CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S 97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND | ||
| | #14 | ||
| Re: Alloy wheel sizes As I know little about me wheels all I can tell you is this: I am currently running a set of these crazy badboys: http://www.fischerclan.de/seicento/B...0_1003_JPG.jpg and wish to purchase these: I would be very grateful indeed if someone could tell me what size spacers ect I require and anything else of importance and also where the best place to buy the required kit from is. Cheers Rich
| | #15 | ||||||
__________________ ![]() 2001 Modded Sei Sporting - GONE!! 1998 Ford Mondeo 1.8LX - P/X'ed 2002 02 Ford Focus 1.6 Zetec w/ Climate Pack! | ||||||
| Alloy Wheel advice | dazz666 | Punto | 4 | 16-01-2006 10:40 |
| Sei Alloy Wheel Bolts! | black_fiatsei | Cinq/Sei > Technical | 0 | 05-08-2005 18:31 |
| Alloy Wheel Fitting (hubcentric or not) | mckcrich | Cinq/Sei > Technical | 6 | 05-05-2005 17:57 |
| Alloy Wheel Centre Caps | paul_treg | Cinq/Sei > Technical | 5 | 28-03-2005 21:43 |
| possible wheel sizes for Fiat Panda | nrbrowning | Panda (Classic) | 6 | 19-05-2004 21:43 |
