The FIAT Forum
Old 19-07-2005   #1
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
Rear disc conversion
I am unlikely to do this as I don't have any money, although i am interested in what needs to be done, how and where to get bits from. I would like to see this thread become a nice collection of knowledge on what needs to be done.. although i know nothing on the subject really so can't help much.
Anyone start the ball rolling, what calipers.. cinq std front ones? Same deal with the discs.
Does it need something to distriubte braking power properly?
Ive no idea!
arc is offline
Old 19-07-2005   #2
Banned
Trader Rating: (2)
Bushboy has donated!
Re: Rear disc conversion
how does the handbrake cable connet upto the calipers with this done?
I know teressa (1.4 cinqi) has it done so maybe she can shed some light on the subject
Bushboy is offline
Old 19-07-2005   #3
Cornish Cinque
AIJ29's Avatar
Trader Rating: (0)
AIJ29 has donated!
Hi
You`d have to get some rear calipers from another car maybe punto gt or uno turbo as these are already made with a handbrake take off,the punto gt uses the same discs on the rear as the cinq does on the front,
Rallycinq has rear discs and he`s using 13" wheels,
Adrian
AIJ29 is offline
Old 19-07-2005   #4
Funny saying here
jamie86's Avatar
Trader Rating: (1)
jamie86 has donated! United Kingdom
I'm sure he also said somewhere he had to get spacers made up...
Tbh i don't see it would actually be that much work looking at it....
Originally Posted by A wise person
Mini invented the giant killer, VW started the genre, Ford & Vauxhall Desecrated it, but the Peugeot 205 GTi was undoubtedly the king of the breed.
jamie86 is offline
Old 19-07-2005   #5
Cornish Cinque
AIJ29's Avatar
Trader Rating: (0)
AIJ29 has donated!
Jamie
I think the spacers he had made are for his front brake conversion to position the uno turbo disc so it would run in the caliper correctly,
Adrian
AIJ29 is offline
Old 19-07-2005   #6
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Rear Brakes
Cinq front discs, Punto GT rear calipers, Small modification to handbrake cable, mounting brackets require fabricated.
D
rallycinq is offline
Old 19-07-2005   #7
Funny saying here
jamie86's Avatar
Trader Rating: (1)
Uno ones could also fit then?
jamie86 is offline
Old 19-07-2005   #8
Cornish Cinque
AIJ29's Avatar
Trader Rating: (0)
AIJ29 has donated!
Originally Posted by rallycinq
Rear Brakes
D
Hi Rallycinq
Any pictures of the mounting brackets? or the complete conversion?
Adrian
P.s any changes to brake bias valve or servo/master cylinder?
AIJ29 is offline
Old 19-07-2005   #9
nippy little runt
microcar's Avatar
Trader Rating: (0)
microcar has donated! United Kingdom
ummm, is it worth the bother for a rear brake conversion? do you need to have super stopping power?
97 1.1 Sporting Gas Flowed and Ported head, Fast Road Cam, Induction Kit. 14" Punto Sporting Alloys. Chip. Alloy Rad. Remus stainless steel exhaust.
microcar is offline
Old 19-07-2005   #10
Banned
darkcircuitUK's Avatar
Trader Rating: (0)
darkcircuitUK has donated! United Kingdom
darkcircuitUK is offline
Old 19-07-2005   #11
rallycinq's Avatar
Trader Rating: (1)
Originally Posted by AIJ29
Hi Rallycinq
Adrian
No piccies at the mo, car away being worked on.
I have a balance bar assembly, but it worked OK ish with the standard set up.
D
Old 19-07-2005   #12
GeX
GeX's Avatar
Trader Rating: (0)
Hmm i am very interested in this too, i was discussing it with arc the other day. I wanna put Punto GT disks etc on the front so i'll have spare Sei calipers etc. I am guessing a full set of Sei front calipers and disks are fine to use. The hang-ups i had were the handbrake and if a balancing unit was needed.
GeX is offline
Old 19-07-2005   #13
Asteris's Avatar
Trader Rating: (0)
Greece
Ok, here's the deal for rear disk conversion on a cento.
Calipers from Uno turbo/Punto Gt (they are the same)
Plate from Uno turbo, fits straight
Disk 228mm from Uno turbo
Hub from Uno turbo
Straight fit, no modifications needed, cento handbrake cable mounts with no problem.
You can also use the 240mm disk (cento's front, Punto GT rear, Alfa 155 rear etc), with same calipers and without changing hub, if you fabricate a custom plate based on the Uno's plate, only the two holes the caliper mounts on have to be 6mm further out.
I have them almost a year now, no probs with the handbrake, no better stopping power, but you can break inside a turn without fearing for the weels to lock unexpectedly. Oh, and far better looks of course...
Asteris is offline
Old 19-07-2005   #14
rallycinq's Avatar
Trader Rating: (1)
You can't use the Sei front calipers on the rear, they have no handbrake facility.
D
Old 19-07-2005   #15
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
Do you need to reduce the fluid pressure to the rear disc brake calipers if you do this?
Pete, Clubcento technical bod.
Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento
fixitagaintomorrow is offline
(S) Updated price list 21/04/2004 Body Stylist Punto 30 09-04-2005 17:02
(G) DJ Bucho is back DJ_Bucho Cinquecento / Seicento 19 14-05-2004 18:41
