| nippy little runt | 6 speed box Hi all just want to ask you brain boxes out there, the punto 55 6 speed box, is it worth having? i have a 1242, in the shed and i was thinking of purchasing the gearbox off my mate, is it worth doing? is the 6th gear a higher gearing? if so will it be better and save more fuel on the motorway? (iknow they dont drink much but hey, every little bit helps!) cheers!
__________________ 97 1.1 Sporting Gas Flowed and Ported head, Fast Road Cam, Induction Kit. 14" Punto Sporting Alloys. Chip. Alloy Rad. Remus stainless steel exhaust. | ||
| Re: 6 speed box 6th gear is slightly longer, but not massively. Don't expect it to give you a load more top speed. I'd probably stick with 5, although it's a bit of a novelty having 6.
__________________ | |||
| | #3 | ||
| Re: 6 speed box Hi, Didn't realise they fitted the 6spd box on the 55 punto, more gears the better on a a small engine, may not be any different top gear ratio but will accelerate through the gears better..... Thanks Paul T
| | #4 | ||
| hi friends :waves: | Re: 6 speed box I'd stick with five, noticed on another post Microcar that you have a Skyline so maybe my arguement will win you over? Anytime spent changing gear means foot off the gas clutch down etc, adding more changes would me longer acceleration times hence many or most super cars do 60 and a lot over in 1st gear giving them quick times. 5 gears for me and 6 if I was turboing. Liam
__________________ CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S 97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND | ||
| | #5 | |||
| mad bad and very very old | Re: 6 speed box
Cheers D
__________________ If it has pistons or tits, its going to be expensive. | |||
| | #6 | |||||
| Re: 6 speed box
| | #7 | ||
| hi friends :waves: | Re: 6 speed box I meant that comment only for eeking every last mph out of the engine to get the best top end. Liam
| | #8 | ||
| mad bad and very very old | Re: 6 speed box Most 6 speed boxes don't have a significantly different ratio in top compared to 5 speed ones. Its the spacing of the gears that are different. The Cinq box has a hell of a gap between 4th and 5th. Its a pain on events where 4th is getting a bit breathless and 5th won't pull. A six speed would help. Cheers D
| | #9 | ||
| Re: 6 speed box What about swapping the 6th gear for a longer 5th gear, say from novitec?? David
__________________ My ebay items: http://search.ebay.co.uk/_W0QQfgtpZ1...Zpeaster2kQ5f1 | |||
| | #10 | ||
| nippy little runt | Re: 6 speed box thanks guys for your views.. im still non the wiser..haha yes my other beast the r33 is just totally different and i have a nismo short shift 6 in that but its difficult to compare that car to the cing because its not in the same league. i like the cinq, its a fun car in town. maybe i will have to try the box and see...
| | #11 | |||
| Re: 6 speed box
so they ate dust. I reckon some highly modified cinqs may be able to challenge a stock skyline especially in the tight bends .BTW: I converted it myself it was originally a Canadian 1991 300ZX NA 2+2 (there are no real 2+2 TT in north america ). | ||||
| | #12 | |||
| Re: 6 speed box
Hi, punto mx1 55 6 speed gearbox have lower gearing! it won't be better to save mor fuel, it will be worse for it. Cinq 1108ccm with 6speed gearbox consumes ca.0.5-1l/100km more on motorway then standard cinqu sporting gearbox, but it has better acceleration. BTW I am thiking about put standard cinqu sporting gearbox instead 6speed to lower fuel consumption...
__________________ Antoine Cinqecento Sporting | ||||
| | #13 | ||
| Re: 6 speed box Using this: http://www.race-technology.com/WebPa...lculation.html and the data from here: http://www.clubfiatpunto.com/foro/fiat_punto_mk1.php if it's all correct then you will have a top speed of 93mph at 6000 revs in 6th, using standard Cinqy Sporting alloys. That may be good for rallying or sprints, or if you can pull 9000 revs more than once If you use a Cinqy Sporting speedo drive with the 6 speed box, the speedo will read rather high too, making you think you're going much quicker (can work it out if someone is all that interested, but I'm tired and haven't slept since yesterday lunch time)
__________________ Pete, Clubcento technical bod. Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento | |||
| | #14 | ||
| Re: 6 speed box Something nobody's mentioned (unless I've missed it) is the fact that the gearbox is longer than the standard one, and will catch your passenger's side tyre on full lock. You will also need to remove or alter part of the wheel arch liner to get it in.
| | #15 | ||
| nippy little runt | Re: 6 speed box Ah thanks for the info.. i really did think the box was a striaght swap with no alterations. umm....
| | FamilyGuy | Marea | 2 | 12-07-2005 12:28 |
| | punto russ | Cinquecento / Seicento | 1 | 09-03-2005 20:14 |
| Punto six speed box | T0m0 | Lets Talk FIAT | 1 | 17-11-2004 00:57 |
| | fordy | Cinquecento / Seicento | 4 | 01-05-2004 23:55 |
| | g1514 | Punto | 1 | 25-09-2003 01:38 |
