The FIAT Forum
Old 27-06-2005   #1
Trader Rating: (0)
mckcrich has donated!
Anti-roll bar
Anyone got a picture of how the ARB should be fitted on a seicento sporting.
I have been trying to get rid of the clunking sound on my sei. I suspect that the ARB might be fitted upside down. So far I've fitted:
  • New ARB bushes
  • New Rear engine mount
  • Powerflex front(and rear suspension bushes)
Most of the clunking has gone but I still get a fairly loud clunk over speed bunps at anything over 10mph.
Picture of the ARB fitted would help, but any other ideas welcome. I think its got me beat!!.
Regards
Michael
Michael,
Developer of the mckcrich chip - more power per £ than any other mod you can buy for your cento (or punto)
mckcrich is offline
Old 27-06-2005   #2
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
Re: Anti-roll bar
Is it a hollow clunk that could be coming from the top of the front suspension struts?
arc is online now
Old 27-06-2005   #3
Trader Rating: (0)
Re: Anti-roll bar
Sounds as though its coming from the bottom of the suspension rather than the top
Michael,
mckcrich is offline
Old 27-06-2005   #4
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
Re: Anti-roll bar
How low is your car?
If it's like Arcs then the arb may be catching the plastic arch liner or the bottom of the inner wing.
Pete, Clubcento technical bod.
Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento
fixitagaintomorrow is offline
Old 27-06-2005   #5
paul_treg's Avatar
Trader Rating: (0)
Re: Anti-roll bar
The top bearing on the strut makes a nice hollow clunking sound when its broke, more so when going over speed bumps, but if your sure its comming from the bottom, the check out the lower suspension arm ball joint, it might have play in it..
Paul T
paul_treg is offline
Old 27-06-2005   #6
Trader Rating: (0)
Re: Anti-roll bar
Its only lowered 35mm (Apex springs so possibly more like 40mm)
Michael,
mckcrich is offline
Old 27-06-2005   #7
Trader Rating: (0)
Re: Anti-roll bar
OK, So its not the ARB - Just removed it and it still makes the knocking. Is there any way of telling if its the upper strut bearing, without taking the strut out and removing the spring. I put the springs on in December and it all seemed OK at the time.
Michael,
mckcrich is offline
Old 27-06-2005   #8
Trader Rating: (0)
Re: Anti-roll bar
Jack it up so the wheel's off the ground, no need to remove wheel. With bonnet open, put your hand on the strut top nut and jiggle the roadwheel up and down. If there's any movement you should feel it.
Old 27-06-2005   #9
Trader Rating: (0)
Re: Anti-roll bar
Cheers pete, I have a go as soon as I get the ARB back on
Michael,
mckcrich is offline
Old 28-06-2005   #10
paul_treg's Avatar
Trader Rating: (0)
Re: Anti-roll bar
Just bouncing the strut top up and down made my duff bearing knock, with car on the floor..
Paul T
(T) Marea 1.8 HLX Anti Roll Bar ksimpson Marea 40 3 Weeks Ago 16:04
(T) new bushes or complete anti roll bar? chris1 Marea 7 30-09-2008 20:15
(T) anti roll bar bush??? Nyx Punto 5 17-04-2005 18:26
(T) anti roll bar bushes broadfield Punto 4 30-04-2004 00:48
(G) sei anti roll bar Blue Seid Boy Cinquecento / Seicento 5 07-08-2003 04:47
