| Hi, Anyone know what size thread is on the steering track rod lock nut.......mine seems to be permanently attached to the track rod and will have to be hack sawed off...... Thanks Paul T
| | #3 | ||
| Re: Track Rod Nut i'll go with 19mm , they do get a bit tight get your blowtorch on it and give it some heat.
| | #4 | ||
| mad bad and very very old | Re: Track Rod Nut I would agree 19 on the wishbone, but this enquiry was the steering arm end. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #5 | ||
| Re: Track Rod Nut Hi, I think I confused everyone, I mean't the thread size, not the spanner size. The spanner size is 19mm..... Thanks Paul T
| | #7 | ||
| Re: Track Rod Nut Thanks, Any Idea what pitch....? Thanks Paul T
| | #8 | |||
Cheers D
__________________ If it has pistons or tits, its going to be expensive. | |||
| | #9 | ||
| Re: Track Rod Nut i have a feeling there a bit finer than standard try 1.25
| | BlackBeast | Cinquecento / Seicento | 8 | 09-03-2005 09:55 |
| Track Rod Ends | Giacosa | Panda (Classic) | 1 | 24-02-2005 19:53 |
| | jamie86 | Cinquecento / Seicento | 4 | 14-12-2004 11:18 |
| | arseofbox | Cinquecento / Seicento | 18 | 22-07-2004 22:20 |
| | Ali P | Bravo / Brava | 1 | 31-01-2004 00:47 |
