| Fuel economy? My Cinq Sporting (bought last week) is giving me terrible fuel economy. I filled it up for £23 and it only did 186 miles before I had to fill up again. My last car was a Clio which did 300 miles for £25 and the car before was a Micra which did the same. I had heard that Cinqs where meant to be good on fuel!
| ...done | Re: Fuel economy? that is pretty bad... i get about £100 miles per £10 give or take, and that isnt driving like a granny either!!! dont kno how that helps u tho!
__________________ R97 cinq 1242 <Ex Team Anthracite > (now sold) | ||
| | #3 | ||
| hi friends :waves: | Re: Fuel economy? The fuel economy will be related probably to your rough running. Re-check it when you get the car running perfect. Out of town at a steady sixty should give you 300miles+ no problem. Liam
__________________ CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S 97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND | ||
| | #4 | ||
| Drives a Punto | Re: Fuel economy? I have carefully removed the plastic cover from my mint condition cinquecento brochure to check out the fuel economy The cinquecento s/sx should do- 42.6 mpg urban cycle 60.1 mpg at a constant 56mph 44.8 mpg constant 75 mph The cinquecento sporting should do- 37.7 mpg urban cycle 60.1 mpg at a constant 56mph 44.8 mpg constant 75 mph HTH joe *slides plastic cover back on brochure and puts it carefully under bed*
__________________ 3rd Fiat - luck as good as ever Last edited by joecinq; 09-06-2005 at 18:59. | ||
| | #5 | ||
| mad bad and very very old | Re: Fuel economy? Did you fill the tank then do the 186 miles, then refill the tank with £23 worth of petrol. Or did you use the gauge. Cento fuel guages are only that, not instruments, and can vary wildly. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #6 | ||
| Banned | Re: Fuel economy? when i worked at thorpe park i was doing around 100 miles a day and would have to fill the tank up around once every 4 days. ive also done london to liecester and back on half a tank. i also did 50 miles with the empty light on too.
| | #7 | ||
| Re: Fuel economy? summuts obviously wrong, my big fat, two litre marea does 350 mile on about £40 (which is 30 to the gallon,so.....) your cinq is doing the same fuel comsumpion as my marea
__________________ http://img128.exs.cx/img128/9284/sma...sigpic27im.jpg | |||
| | #8 | ||
| Re: Fuel economy? Wow 60 mpg, damn next time im on the motorway im driving at 60. Especially if it gets my 15 more mpg than 75mph I get around 250-270 miles from a tank £22 optimax only!!!.
| | #9 | |||||
| Re: Fuel economy?
| | #10 | ||
| Re: Fuel economy? Check the plugs & leads, its amazing how much they can affect the performance & fuel economy! Up until 2 days ago I was running Bosch super 4s & new(ish leads), both had only done 9000 miles but my economy & performance was getting worse by the week. I've now changed the plugs & checked the leads & the car is running fantastically again. Cinqs seem to eat spark plugs so its probably worth just replacing them with some standard replacements (£10 a set) every 6-7000 miles, rather than the expensive £20 + jobbies which will work nicely but fade away nearly as quickly.
__________________ Cinquecento............Its not the size its how you use it! http://www.fiatforum.com/gallery/dat...ard_Warhol.jpg 98 R - Imola blue Cinq, Sei Abarth steering wheel, PI -50mm springs, bilstein uprated shocks,OMP upper strut brace, K&N/ Pipercross filter (depending on mood!), Supersprint exhaust & some fookin' loud airhorns!!! | |||
| | #11 | ||
| Re: Fuel economy? Thanks for the advice, but I replaced the plugs and leads only last week!
| | #12 | |||
| Funny saying here | Re: Fuel economy? This doesn't really help you i know but i just got 218miles from £25.01
| | #13 | |||||
| Re: Fuel economy?
| | #14 | |||
| Funny saying here | Re: Fuel economy? Not a standard cinq though (see Sig)
| | #15 | |||
| Re: Fuel economy?
__________________ Cinquecento............Its not the size its how you use it! http://www.fiatforum.com/gallery/dat...ard_Warhol.jpg 98 R - Imola blue Cinq, Sei Abarth steering wheel, PI -50mm springs, bilstein uprated shocks,OMP upper strut brace, K&N/ Pipercross filter (depending on mood!), Supersprint exhaust & some fookin' loud airhorns!!! | ||||
| 1.6 16v Fuel Economy | jcarrier | Multipla | 6 | 12-10-2006 07:35 |
| | jonathon | Marea | 3 | 26-04-2005 17:57 |
| | smurfhead | Cinquecento / Seicento | 20 | 02-02-2005 00:47 |
| | Bushboy | Cinquecento / Seicento | 39 | 18-10-2004 20:37 |
| | StiloBoy | Stilo | 17 | 01-03-2004 03:21 |
