The FIAT Forum
Old 29-05-2005   #1
Suck Squeeze Bang Blow
philbo's Avatar
Trader Rating: (0)
philbo has donated! United Kingdom
air box
i have a 899 sx with the infamous flat spot. ive read that you need to upgrade the induction system either by fitting a high flow filter element and drilling holes in the bottom of the airbox to allow more air in or just fitting a custom air induction kit. these can be quite expensive by the looks of things so my question is can i replace mine with a sporting air box? do the sportings suffer from this flat spot aswell? or should i just stump up for a new filter? money is an issue at the mo as ive spent a LOT getting it through the mot.
cheers for any advice
philbo is offline
Old 29-05-2005   #2
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: air box
Its the 1108 that has the imfamous flat spot, not the 899, however the 899's inlet manifold is higher than the 1108 so you can't put a sporting filter on. That leaves putting something else on the end of the 'bob', or throttle body cap.
Do a search on here and you'll find plenty of suggestions along the lines of the GSR one.
Could be worth a try.
D
rallycinq is offline
Old 29-05-2005   #3
philbo's Avatar
Trader Rating: (0)
Re: air box
ah. maybe mine wants to be a grown up 1108? hehe. might go for the k&n replacement filter when i do the head gasket etc. how often do you have to clean these?
cheers for the info btw
philbo is offline
Old 29-05-2005   #4
rallycinq's Avatar
Trader Rating: (1)
Re: air box
If you are doing a head gasket on an 899 cos its overheated, lap the valves in. Reduces the chance of a high spot on a valve or seat causing problems later.
Been there, done that.
D
Old 30-05-2005   #5
Cento Boy
surfin_fella's Avatar
Trader Rating: (0)
surfin_fella has donated! Australia
Re: air box
If you have a spare 90 notes (IIRC), get in touch with GSR. The BMC induction kit they offer (F2i, I believe) is really impressive. I fitted one to a Cinq SX last weekend and it revs so much easier and is much more throttle resposive. Not to mention the huge roar it makes in 2nd and 3rd
Sie - Proud advocate of Centoism
Cinquecento60
Clubcento - The UK Cinquecento and Seicento Owners Club Clubcento Forum
surfin_fella is offline
Old 30-05-2005   #6
Cento Boy
Trader Rating: (0)
Re: air box
Just to add:
With the kit I've spoken about, you will need to get hold of a seperate oil breather filter though. K&N do one for about £15 but why pay that when halfords sell a Ripspeed one for £8.99?!
Just wish I'd taken a few pics to show you how it's done now
Cinquecento60
Old 31-05-2005   #7
Trader Rating: (0)
Oldschool has donated!
Re: air box
Originally Posted by surfin_fella
Just to add:
If you reroute the breather hose you can connect it to an threaded airline fitting, which you screw into the plastic cap
Oldschool is offline
(G) Air Box Modification polecat Marea 81 06-11-2008 18:02
(G) Airbox on mk2 45 chrisunoman Uno 13 23-12-2004 01:15
(T) air box mod revisited jbackg Marea 1 18-08-2004 01:33
