The FIAT Forum
Old 16-05-2005   #1
BEN IS A SMACK ED!!!
benfredjosh's Avatar
Trader Rating: (0)
benfredjosh has donated! United Kingdom
I OPENED MY ECU (99 sei spi)
hey for all of you who are wondering if a sei spi has a removable chip YES it is its fully detachable but if your going to remove it be careful i have removed mine 2 see and i nearly snapped the prongs :S be careful lol! i thought i'd share my findings with u all hope it helps someone??
Its got..
~ Migilia spiders in Graphite Grey
~ Custom stainless exhaust 3 1/2" rolled out tip
~ GSR induction kit (red) with cold air feed
~ Pipercross ecotek breather Fitted as oil breather(red)
~ Abarth Kit fitted
~ Punto 75 Camshaft
~ Soon to have , Novitec chip, 40mm Tb from tricker.
& sei sporting seats covered in Black leather!!.
http://img169.echo.cx/img169/8436/benjosh7qp.gif
benfredjosh is offline
Old 16-05-2005   #2
...done
Trader Rating: (1)
mase has donated! United Kingdom
Re: I OPENED MY ECU (99 sei spi)
hmmm that is actually quite interesting as i am lookin at gettin my 97 R reg cinq chipped some time this week i hope... but i am sure i have been told that fiat started soldering the chips in after 1997!
anyone kno if this is true on the cinqs as i cant b assed to take my ecu apart unless i really need to!!!
R97 cinq 1242 <Ex Team Anthracite >
(now sold)
mase is offline
Old 16-05-2005   #3
Trader Rating: (0)
Oldschool has donated!
Some are soldered other are plugged on a soldered carrier. It was just as the factory was set up.
If you have a soldered one take it out and solder a socket in.
Oldschool is offline
Old 16-05-2005   #4
...done
Trader Rating: (1)
oic so it is more a case of luck of the draw weather yours was made soldered or not!
soldering a socket in, now that is a good idea.... pity i have not done any soldering since i was about 11 in school!
suppose i could just get a different ECU and run that with a chip and get an external immoblisor!
(now sold)
mase is offline
Old 16-05-2005   #5
taffy git
gaz.d's Avatar
Trader Rating: (2)
gaz.d has donated! United Kingdom
it only takes 2 mins to open it up and have a look mase
there is a recent thread about post 97 ecu's and the ones that have been opened aren't soldered after all
Gaz
Marea Weekend
gaz.d is offline
Old 16-05-2005   #6
Trader Rating: (0)
mckcrich has donated!
Its a tricky job to take out the soldered chip. The board is plated so the best (only) way to remove the chip is to cut all the pins and remove each one separately. If you try to remove the whole chip at once you will not be able to keep the solder on all the legs liquid and you will quite likely damage the board trying to remove it.
The Sei ECU is a different model from the Cinq I suspect they went back to plug-in so that they could be more flexible with changing the map chip if there was any problems.
Regards,
Michael
Michael,
Developer of the mckcrich chip - more power per £ than any other mod you can buy for your cento (or punto)
mckcrich is offline
Old 17-05-2005   #7
...done
Trader Rating: (1)
bargin idea... i am on a mission on thursday to change all shocks on my own in a few hours haha so i will have a cheeky look while i am at it!
(now sold)
mase is offline
(T) opening the ecu in my sei (pre facelift) benfredjosh Cinquecento / Seicento 13 16-05-2005 01:38
GSR Induction Kit SPI sei ONLY!!! AppleSei Auction Watch 0 22-04-2005 17:18
(T) all sei SPI owners please read gaz.d Cinquecento / Seicento 1 06-10-2004 17:11
(T) 1999 Punto 1.2 8V SPI ECU chipping help smokeme Punto 20 22-08-2004 17:10
