| Boot light Does anybody know how to add a boot light in a Sei (SX)? All I need is a +ve and -ve, and then I can put a switch and everything there. Any ideas if there are any power cables leading to the boot area?
| this is where i stand | Re: Boot light i have a set of blue cathode tubes to light my boot, they are wired via a push to break switch that the parcel shelf sits on. Are you using a normal light, or plan to use cathodes? If you plan to use cathodes, you need to be careful as the voltage when the engine is running will kill them. They are designed for 12v, not 13.8v. To deal with that, i bought a 12v regulated supply from maplin for around a tenner and wired it in behind my dash then ran wires through out the car (including to the boot) to run any cathodes i wanted to install. So in answer to your question, no i don't know of any lines in the boot!
__________________ | ||
| | #4 | |||||
| Re: Boot light
I was thinking about a cold cathode, but getting 12V may be difficult, maybe I'll be able to find some 15V cold cathodes that will work?
| | #5 | |||
| Absentee |
__________________ Ci sono qualche cose nella vita che non hanno prezzo Per il resto, c'è contanti | |||
| | #6 | |||
Buy a regulator, and wire it in. Its very useful, i have cathodes in my foot wells, under the seats and in the boot - they all run off the regulated 12v line. edit - could always tap the line to the tail lights?
__________________ | |||
| | #7 | ||
| hi friends :waves: | Re: Boot light What about those push on lights from the catalogues? Or is that too easy, practical and un-modding like? Liam
__________________ CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S 97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND | ||
| | #9 | |||||
| | #10 | ||
| this is where i stand | Re: Boot light well if you're being cheap about it, buy the voltage regualtor chip and wire it up urself. They can be had for around a quid - i just couldnt be arsed wiring one up, so bought the box. 12v regualted supply is useful for things like TFT screens, walkie talkie charging, etc. I do use mine a bit
| | #11 | ||
| Re: Boot light I've got an idea now ![]() I think I'm probably just gonna get some batteries, and wire up some ultra bright LEDs. The batteries should last ages with LEDs and I can probably put it in my spare wheel. I'll have a little micro switch for when the boot opens too.
| | #12 | ||
| this is where i stand | Re: Boot light that'd work.. i don't see why you won't just run a power line down the car tho ![]() ah well! the switch you'll need is this one: http://www.maplin.co.uk/Module.aspx?...rldID=&doy=8m4 I drilled a small hole in the support for the shelf and put the switch in there.
| | #13 | ||
| ...done | Re: Boot light how easy is it to press? i mean i dont have 6x9's on my parcel shelf and dunno if it would weigh enough to press the switch when down.... i well fancy havin a blue neon to light the boot, pain in the ass that there is no light in there!!!
__________________ R97 cinq 1242 <Ex Team Anthracite > (now sold) | ||
| | #14 | ||
| THE BLUE BUG Join Date: Apr 2004 Location: Glengormley, N.I, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: Boot light how come your sei has no boot light, did older ones not come with one?
| | #15 | |||
| | faster4_tec | Punto | 6 | 24-03-2008 01:26 |
| | davepunto | Punto | 6 | 09-11-2005 23:31 |
| | punto team | Punto | 7 | 29-11-2004 15:27 |
| | Stevey | Punto | 2 | 20-03-2004 06:36 |
| | BagPuss | Cinquecento / Seicento | 4 | 23-01-2004 16:53 |
