| How to increase power? Sorry if this has already been asked, I'm new on here! I have a 99 899cc Sei, is there any easy ways (i.e. clipping stuff on) of improving performance. I was thinking about: 1) Spark plugs 2) HT leads 3) Air Filter (which type) 4) Induction kit? (which type is it easy) 5) Any other ideas? I love the car, the performance around town is great, but it's a bit lacking on the motorway. Also, I can get hold of some sporting seats, do these just bolt on, and would that invalidate the insurance? One last question, is it possible to fit an aftermarket airbag to the sei? Thanks
| Re: How to increase power? i dont think any insurance company would pull you up on having Sporting seats in a standard cinq. induction kit probably easiest way to get a power boost, dont think to difficult to fit either
__________________ Apparently 3 out of 4 people make up 75% of the world population | |||
| | #3 | ||
| Re: How to increase power? thanks for the reply, am just struggling to find an induction kit for the 899, they all seem to be for 1.1
| | #4 | ||
| Re: How to increase power? make your own induction kit, do a search on it through the forum, many have already done it. all you do is get some pipe coming from the black bit on top of the throttle body lead it to a nic cone near the front of the bumper where all the air comes in, job done
| | #5 | ||
| Ah. Not good... | Re: How to increase power? IMO an induction kit is a bit OTT for a 899 (might be pushing a 1108 come to think of it......). The reason I say this is because the airflow is so dramatically increased that it confuses the fuelling of the ECU, giving rougher running. IMO a high flow filter (K&N element or similar) with a couple of drilled holes in the airbox would be better (and cheaper! The problem is that noone produces off the shelf tuning parts for a 899 AFAIK. I think the TBs are the same on the 1108 and 899, but I'm not 100% sure. Tricker produces 40mm throttle bodies, so you could change that if they are the same. Changing the HT leads is generally pointless unless you need to change them...you may get 1 bhp extra by uprating the sparks, but you may not notice it. If you want more serious performance, then you're looking at head work, uprated cams, lightening, boring/stroking (if you can find suitable parts), a custom turbo should be a possibility. Depends how much more performance you want. Air filter and sparks wouldn't add all that much, but you should notice a difference in the drivability of the car. Hope this helps EDIT: I forgot exhausts! Smoothing the inlet/exhaust manifolds and matching the ports on the cylinder head to the manifolds would improve the engine, as would a free flow exhaust - but don't go mad with the bore size - you might lose power Last edited by chaos; 06-04-2005 at 09:53. | ||
| | #6 | ||
| Principality Retained :) | Re: How to increase power? I had a K+N and a Group N backbox on my 899cc...Twas much better! The GrpN would need to be obtained from Demon Tweeks, Id think, as the supplier I used have stopped making them..
| | #7 | ||
| Re: How to increase power? thanks for all the help!
| | #8 | |||
On an 1108, the problem with drilling the airbox is that it puts the intake right over the exhaust manifold so might sound wild but will draw in hot air by the bucketful, but agree it might be useful on an 899 as the box is more remote.
__________________ Pete, Clubcento technical bod. Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento | ||||
| | #9 | |||
Pete would the ECU learn the engine characteristics well enough if you bored/stroked the block, increased the comp. ratio, etc.? Most of my tuning ideas come from tuning A series engines in Minis, and a hike of 30bhp for a 1275cc is the max possible on the standard ECU. I don't think its a 'learning' ECU like on a cinq. I like the idea of having a modded 899 engine, but was wondering bout the ECU. | |||
| | #10 | ||
| | #11 | |||
The 899 is a very old design, only a 3 bearing crank jobby a bit like the A series, and will need the full lightening and balancing treatment if you want to use revs and have power. In all honesty, it'd probably be cheaper to stick a 1242 8v in.
| | #12 | |||
| | #13 | |||||
It isn't great on the m/way lol I did 280 miles on Sunday, and I found that I had to change down for the slightest slope on the m/way. There was one part of the m/way where I couldn't even do 70mph flat out in 4th gear lol.
| | dylan.gibson | Marea | 17 | 01-06-2006 22:22 |
| Guide: How to wire an Amp | Luke | I.C.E | 3 | 11-07-2005 18:33 |
| | Bigmatty | Stilo | 8 | 26-02-2005 18:45 |
| | mckcrich | Cinquecento / Seicento | 9 | 04-12-2004 17:55 |
| | hgt powered | Punto | 17 | 23-07-2004 19:47 |
