| Ah. Not good... | Rev counter I know there a probably a million threads asking this question but here goes - rev counters and 899 Cinqs. I have 2 questions 1 - Can you use a 2 cylinder bike rev counter? 2 - Failing that, I understand that a 4 cylinder rev counter will under read by exactly half. Is that right cos of the dual coil system? What I might do is buy an aftermarket 4 cyl counter off ebay or something (halfords do one but it states for single coil only - but I'd probably ignore that ) and change the numbers - change 1 for 2, 2 for 4 etc. and see if I can get a 5,000 rpm max one! Cheers in advance | ||
| Re: Rev counter 1. Should be able to, I've hooked a Sei rev counter up to a cinq and it reads half so the ecu must give out a standard type 4 cylinder signal. 2. Might read a bit jumpy, the sei one did.
__________________ Pete, Clubcento technical bod. Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento | |||
| | #3 | ||
| Re: Rev counter Hi, I've stripped some cinq sporting clocks down, and there should be a way of making it read double what its supposed to by changing some electronic components, so that it would read correct....if you know what I mean.. The circuit board inside has a few resistors, a capacitor and an ic control chip(pulse counter), the count should be controlled by the resistors I think.. Will have to investigate deeper I think....when I get some time Thanks Paul T
| | #4 | ||
| Ah. Not good... | Re: Rev counter Paul, any scrapyards around by you? Where in South Wales are you? | ||
| | #5 | ||
| Ah. Not good... | Re: Rev counter Just thought of something - I could get an aftermarket tacho and make a dial face as described in one of the stickys, but every 500 rpm = 1000 actual rpm! Just need a 4/5000 rpm max rev counter (like off a 4 cyl lorry - I'll have to have a root around). | ||
| | #6 | ||
| Re: Rev counter Hi, Just outside Neath, there's not much in the scrappies at the mo, a 94 cinq 899cc in PickupSpares and a 95 899cc in Owens in Aberdare, plenty of uno's though... Thanks Paul T
| | #7 | ||
| Ah. Not good... | Re: Rev counter Owens usually have a Cinq, I had to get a rear wiper arm after some little F****r (I have a good idea who) snapped my old one off. Is it a red cinq with mild frontal damage missing its rear wiper, to the right as you go into the yard? | ||
| | #8 | ||
| Ah. Not good... | Re: Rev counter Paul are you intending going to Max Power Live this year? | ||
| | #9 | ||
| Re: Rev counter Hi, Yeah I know, its also missing the the front nearside susp leg(on mine) and the centre front wiper support(soon to be on mine), which I had to hacksaw off in the rain, cos its allways raining there.... Where abouts you from then..... Thanks Paul T
| | #10 | ||
| Ah. Not good... | Re: Rev counter I know what you mean about the rain, when I went there (last summer) the carpets were swimming and the wheels were on the back seat! | ||
| | #11 | ||
| Re: Rev counter Hi, Na not going to max power, getting a bit old now for that sort of thing.... Think max power just goes a bit too far these days, its forgotten about the people who can't afford to blow 30k of mods on a car..... Any good scrappies up your way.....? Thanks Paul T
| | #12 | ||
| Ah. Not good... | Re: Rev counter Nah Owens is the best. There is one in Taffs Well, just outside Cardiff, but they are tiny compared to Owens | ||
| | #13 | ||
| Re: Rev counter Hi, Has anyone got a good photo of the timing pulley on the cinq sporting engine, the rev counter I think takes its signal from this, as when I calculated my rev counter reading's when I put a signal in it was just under half(45%) of the reading it should have had, this makes me think the rev counter on a sporting is sensor controlled and not ignition controlled. Thanks Paul T
| | #14 | |||||
| Principality Retained :) | Re: Rev counter
Crank or Cam end? I presume you mean crank end.. FYI, the TDC sensor takes its signal from the outer ring of the alternator drive pulley (thats toothed), and that bolts into the crank pulley. I can get piccys, but not till sat-sun!
| | #15 | ||
| Ah. Not good... | Re: Rev counter Could a 2 cylinder car tacho (e.g. off a 2CV or a 126 or something) fit? There is 1 tacho on ebay that is suitable for 2 cylinder cars. Would that work? Cheers | ||
| | puntostyling | Punto | 2 | 16-12-2004 10:35 |
| | steventodd | Punto | 1 | 11-07-2004 06:26 |
| | Azmondo | Punto | 0 | 28-02-2004 02:23 |
| | Bushboy | Uno | 7 | 15-12-2003 00:17 |
| | padd | Punto | 2 | 05-09-2003 18:43 |
