Technical  Locking problem
bluecinqLHD
ALICANTE
:bang:
I am after some help, the problem im having is if i want to lock the passenger door (Cinquecento S 900, not central locking) i have to use the key or lock the door from the inside when the door is closed from the drivers seat,
Is there a way for the passenger to lock the door without the key.
:D BLUECINQ LHD
Hold the exterior handle up while pressing the door button down. If that don't work, and it only works on some, then there is nothing you can do. Remember that our passenger door is Polands drivers door and is designed to stop dozy people lockng their keys in the car.
D
thanks rallycinq,
the Fiat i have is LHD so it my passenger door is your drivers door. what your saying makes sence, i just thought there might be away of adjusting the locking system.
Thansk again. (y)
P.s. also i have only just noticed that the reflective part inside the head lamps is not attached ot anything (on both) the reflective part just moves around is this correct :yuck:
Bluecinq LHD :D
bluecinqLHD said:
thanks rallycinq,
Thansk again. (y)
Bluecinq LHD :D
Silly little me, didn't look at your location, anyway, no the reflectors should not move about. Usually the mounts have broken off and you will need new lamps.
D
