The FIAT Forum
Old 20-02-2005   #1
Trader Rating: (0)
Cinq Sporting Electrical Problem - Brake lights/rear lights
Can anyone out there help me please??
Cinq Sporting 97R
Electrical problem on Fuse 13 (7.5amp). The fuse blows - but not straight away.
With lights on - without pressing the brake, the brake lights also come on
With lights off - press brake and the dash lights (speedo/tacho) come on
Realise there is a short somewhere but unable to find it.
Checked brake switch, and found ok
Anyone have any ideas?
Regards,
namb
UPDATE:
PROBLEM SORTED - THERE WAS A SHORT BETWEEN THE BRAKE AND TAIL LIGHT FILAMENTS. NOTICED WHEN EACH BULB WAS EXAMINED CAREFULLY. THE TAG HOLDING THE FILAMENT HAD OPENED AND BREACHED THE GAP BETWEEN THE FILAMENT POSTS. THIS THEREFORE CAUSED THE SHORT - FUSE BLOWING - ALONG WITH INDUCING THE OTHER CIRCUITS.
MANY THANKS FOR YOUR SUGGESTIONS....
REGARDS,
NAMB
namb is offline
Old 20-02-2005   #2
AKA Dan
D4NS's Avatar
Trader Rating: (0)
D4NS has donated! United Kingdom
Re: Cinq Sporting Electrical Problem - Brake lights/rear lights
Have you replaced any bulbs recently, could be you have the wrong wattage?
I had this, but my dash lights were coming on when i braked.
D4NS is offline
Old 20-02-2005   #3
hi friends :waves:
Liam's Avatar
Trader Rating: (0)
Liam has donated! United Kingdom
Maybe you've replaced a twin filament bulb with a singular, brake lights also sharded with side light, this could be your problem.
Liam
CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline
Old 20-02-2005   #4
Drives a Punto
Trader Rating: (0)
joecinq has donated! Yemen
The exact same thing happened to me when i out the reverse bulb into the brake light socket and the brake bulb into the reverse one.
I think this would be what liam said ...
I have put a 10amp fuse in there now - replacing the 7.5 and it has worked for about a month like it
3rd Fiat - luck as good as ever
joecinq is offline
(T) Brake Drum problem Redpunto2004 Punto 4 16-11-2004 14:50
(T) Another brake light problem cruisestoke Cinquecento / Seicento 2 01-10-2004 13:31
(T) Brake light staying on when lights on Shakey Cinquecento / Seicento 2 22-09-2004 10:50
(T) Brake lights sort of not working...sometimes Sando Cinquecento / Seicento 2 18-11-2003 06:47
(T) Rear brake lights problem Bois_aiii Cinquecento / Seicento 4 24-09-2003 04:48
