The FIAT Forum
Old 16-02-2005   #1
Trader Rating: (0)
Erratic Idling
Greetings to you all from a newbie!
After having the head gasket changed a month ago, my Cinq 900cc started idling erratically when warm. At the lights, it either idles very fast or oscillates. The mpg has taken a hit as well.
Garage which did the HG says it could be potentiometer or stepper motor, but would need a FIAT diagnosis (£70) to make sure.
Could there be anything else worth looking at before I go to FIAT?
Thanks.
GreenCar is offline
Old 16-02-2005   #2
paul_treg's Avatar
Trader Rating: (0)
Re: Erratic Idling
Welcome, you could try cleaning the idle control valve, its on the rear left of the throttle body, held in by two torx head screws, give it a blast with choke and carb cleaner.......they do get ****ted up and can give the symptoms you have described. Also make sure all the pipes and wires going to the top of the engine are secure since the head was removed..
Paul T
paul_treg is offline
Old 16-02-2005   #3
Suck Squeeze Bang Blow
philbo's Avatar
Trader Rating: (0)
philbo has donated! United Kingdom
Re: Erratic Idling
a diagnostic check at fiat dealers is not £70! more like £20.
a 70 quid diagnostic would write mine off! hehe
philbo is offline
Old 17-02-2005   #4
Trader Rating: (0)
Re: Erratic Idling
OK philbo - to be fair if it takes less than half an hour I am quoted £35, longer than that £70. An intermittent fault like this could well push it over half an hour.
GreenCar is offline
Old 17-02-2005   #5
philbo's Avatar
Trader Rating: (0)
Re: Erratic Idling
i was quoted 20 quid. simple diagnostic. plug machine into car read off whats wrong give car back.
"sorry sir, your rotary pericombobulator has given up the ghost. that'll be 20 quid. would you like fries with that?"
mind you the red light is on on mine so if yours is just acting funny then yeah i see what you mean. ill shut up now.
philbo is offline
(T) Pesky punto idling noises - update marina_vitromanovic Punto 6 04-02-2005 18:40
(T) erratic idling PeteO’Punt Punto 6 13-12-2004 13:50
(G) UNO 1.1 i.e. idling problem andre79ge Uno 5 11-10-2004 13:28
(T) uneven idling (again) and acceleration Achtung Bravo / Brava 6 28-02-2004 15:13
(T) Erratic Idling Jonah431 Cinquecento / Seicento 2 19-02-2003 05:11
