| You Can Do it!!! | Seicento 900cc rocker cover gasket Has anybody had problems with this and is an easy DIY fix? Or will this cost me some money. Hope not i'm skint
| Re: Seicento 900cc rocker cover gasket Are you trying to say that yours is leaking and how do you go about fixing it yourself ?
__________________ ~~~~~~~~~~~~~~~~~~~~~~~~ Carla, Minty & Harvey!! | |||
| | #3 | ||
| You Can Do it!!! | Re: Seicento 900cc rocker cover gasket Yeah thats wot i am saying. Im not to bad at machanics. And yeah its leaking.
| | #4 | ||
| Re: Seicento 900cc rocker cover gasket rocker cover gasket costs a couple of quid and not long to fit, perfectly capable of being a DIY job
| | #5 | ||
| You Can Do it!!! | Re: Seicento 900cc rocker cover gasket Thanks mate that has been really helpfull. Glas u guys come in handy
| | #6 | ||
| Re: Seicento 900cc rocker cover gasket I had the same problem with my 899cc Sei. A few £ for the gasket, and my dad swapped it when I was at work one day. I think it's best to just lift the cover up and leave the injector etc bolted on. Make sure the bolts are tightened to the correct tension though. To tight and it will wear the gasket out, too loose and it'll leak anyway.
| | #7 | ||
| Re: Seicento 900cc rocker cover gasket Presuming the 899 Sei engine is the same as a Cinq....I think you need a cut down allen key to reach the head of one of the screws
| | #8 | ||
| mad bad and very very old | Re: Seicento 900cc rocker cover gasket It is two of the screws, the ones under the throttle body. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #9 | ||
| Re: Seicento 900cc rocker cover gasket Cool. I knew there was at least one !
| | #10 | ||
| Re: Seicento 900cc rocker cover gasket Hi, You will have to disconnect a small water pipe that go's from the thermostat to the throttle body, other than that its an easy job, cables need to be disconnected from the throttle body as well. Thanks Paul T
| | Grayedout | Cinquecento / Seicento | 5 | 19-11-2004 23:57 |
| | Bushboy | Cinquecento / Seicento | 20 | 20-06-2004 23:51 |
| | bravomygoodman | Bravo / Brava | 1 | 19-06-2004 00:54 |
| | mcdi7aw2 | Cinquecento / Seicento | 4 | 03-02-2004 05:25 |
| | chuckie | Cinquecento / Seicento | 3 | 12-02-2003 00:20 |
