| taffy git | I havent had chance to look where yet, but the water level is below min im guessing worst case scenario is the rad, i need the car for tomorrow as im off on an adventure lol, would it be possible?? what else can i look for, i dont really want to take it upto the garage yet
__________________ Gaz Marea Weekend | ||
| Re: I have sprung a leak top the water bottle up and then start the engine up to pressurise the system. if its the rad gone, you'll see it p155ing out from somewhere - mine was shooting straight through the bumper!!!
__________________ matt Poor little Tarquin R.I.P. now an 05 Corsa SXi <-- not a patch on Tarquin | |||
| | #3 | ||
| :) | Re: I have sprung a leak Add egg to your water Where's the adventure Gareth?
__________________ Now drives: '52 Megane 1.9dCi ![]() Past: Y-reg Fiat Brava JTD (Pale Blue) (2006) M-reg UNO (2003-2004) '51 Fiat Brava 80 SX (black) (2006) | ||
| | #4 | ||
| taffy git | Re: I have sprung a leak add egg to water - i aint baking a cake ![]() im guessing it isnt the rad then as i managed to drive 20 miles to my mates house and back again ![]() the adventure is un-important, but i am going to see someone
| | #5 | ||
| Re: I have sprung a leak if its the rad you could try the sealant stuff that you put in the water that seals up holes, this could do as a temp measure until you get a chance to sort it? You check all coolant pipes when the car is running. alos the bleed nipples are on tightly? HTH David
__________________ My ebay items: http://search.ebay.co.uk/_W0QQfgtpZ1...Zpeaster2kQ5f1 | |||
| | #6 | ||
| Fat pigeon... APPLE! | Re: I have sprung a leak Fill it with water, run the engine up to temperature and look under the bonnet for steam. And pray it's not the bloody head gasket
__________________ Back in the day: mildly-modded Punto 55SX; rusty Ford Capri 2.0 Laser Then: mk2 Focus Zetec Ti-VCT; same Capri, less rust ![]() Now: Bravo Dynamic 150 MJet, in red, with extra toys same Capri, same rust ![]() | ||
| | #7 | |||
| __________ | Re: I have sprung a leak
you know what its means if you keep loosing water and theres no leak dont you? lets hope its not that and you just didnt do cap up tight, has it gone down again?
__________________ Binki | |||
| | #8 | ||
| taffy git | Re: I have sprung a leak i just been to have a quick lok, its not the rad itself ![]() there is water collected on the suspension arm thing - i dont know the correct name ![]() i cant see where its dripping from, cause i cant jack it up on the uni car park
| | #9 | |||
| Funny saying here | Re: I have sprung a leak Water pump seals maybe gone then.....
| | #10 | ||
| Moderator | Re: I have sprung a leak Sounds like a loose hose. That's best case scenario.
| | #11 | ||
| Fat pigeon... APPLE! | Re: I have sprung a leak If the Sei's engine bay layout is similar to the Punto's, then if its on the drivers side it could be radiator bottom hose/water pump; if its on the passenger side it could be top hose/thermostat housing. Also check the heater hoses and any bleed screws.
| | #13 | |||
__________________ Back in the day: mildly-modded Punto 55SX; rusty Ford Capri 2.0 Laser Then: mk2 Focus Zetec Ti-VCT; same Capri, less rust ![]() Now: Bravo Dynamic 150 MJet, in red, with extra toys same Capri, same rust ![]() | |||
| | #14 | ||
| taffy git | Re: I have sprung a leak dont you have a loss of power and mayo type stuff on the oil cap, i thought head gasket uses up water not lleaks it out
| | #15 | |||
mind the car hasn't been run since it went a week ago, so maybe thats why? No idea why your water's frothy then, if you've got no mayo then your H/G should be fine. I didn't notice any power loss though, it ran perfectly before I parked it up.
| | tommyd | Punto | 5 | 15-11-2005 19:45 |
| | gholian | Uno | 0 | 04-01-2005 16:21 |
| | blackpool_uk | Punto | 9 | 15-12-2004 22:07 |
| | mdsremos | Cinquecento / Seicento | 9 | 09-10-2004 23:29 |
| | pyrrho | Punto | 5 | 22-07-2004 21:52 |
