| Just noticed my engine coolant is running below the MIN. line on the tank. Can anyone tell me the mix or spec of the coolant please?? My car is a 2000y W reg. Seicento Sporting. Muchas Gracias
| types his title here | Re: Engine Coolant The official mix from fiat is meant to be 50:50, i think i might be right in saying you can do less than that about 30% antifreeze for -15 degrees proctection. Not sure what mine is i a garage done it when i had a new rad put on. Coolants range from lasting 2 years to 5 years, depending on price, anything around there from halfraunds should do fine, hope this helped Nath
| | #3 | ||
| Re: Engine Coolant I usually chuck 2 litres of antifreeze in then fill up with water, so about the 50:50 for me. If the antifreeze hasn't been changed recently, it's as good an excuse as any for some fresh as it also helps prevent corrosion on the inside of the engine.
__________________ Pete, Clubcento technical bod. Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento | |||
| | #4 | ||
| Cento Boy | Re: Engine Coolant What's the best way to go about draining the coolant? I would check my Haynes but I'm at work and I'm sure the reply will help someone along the line!lol
__________________ Sie - Proud advocate of Centoism Cinquecento60 Clubcento - The UK Cinquecento and Seicento Owners Club Clubcento Forum | ||
| | #5 | |||
| Funny saying here | Re: Engine Coolant Pull the hose of a step back quickly.lol
| | #6 | ||
| Re: Engine Coolant if you dont, it goes all down your arm ![]() Ive got "halfords advanced" coolant - if you have an alloy radiator, you need a different type of coolant to a normal one (or so the instructions that came with my rad say)
__________________ matt Poor little Tarquin R.I.P. now an 05 Corsa SXi <-- not a patch on Tarquin | |||
| | #7 | |||
__________________ Sie - Proud advocate of Centoism Cinquecento60 Clubcento - The UK Cinquecento and Seicento Owners Club Clubcento Forum | |||
| | #9 | ||
| Re: Engine Coolant Nah, do it hot and the oil runs out better. All over the place, eh Sie? ![]() The best way to drain the water is to take the expansion bottle cap and bottom radiator hose off - again watch out if it's warm, this one best done when cool. dude.
| | #11 | ||
| Re: Engine Coolant i'd sooner get burnt
| | #12 | |||
| hi friends :waves: | Re: Engine Coolant
Liam
__________________ CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S 97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND | |||
| | #13 | ||
| Re: Engine Coolant Funny enough, i've been talking about doing this today. But bit worried as been told that if not done properly and leave air in rad it'll cause pos head gasket damage?!?!? Not sure whether to believe it.... So, let me get this right. (1) Undo hose at bottom of rad (2) Flush crap out with the help of a hosepipe. (3) Re-attach hose to bottom of rad and fill with 2L of antifreeze then will to max on water tank? Is it true you then have to turn heaters on in car? Any type of anti freeze ok? Cheers guys. matt
| | #14 | ||
| Re: Engine Coolant just behind the drivers side headlamp, there is a hole in the wing with a black pipe coming out and a butterfly bolt in it. If you undo that, it's a bleed-screw for the radiator to get rid of the air-lock.
| | #15 | ||
| Re: Engine Coolant There's also one on the bulkhead next to the battery. Go for an antifreeze suitable for use in mixed metal engines and make sure it contains corrosion inhibitors.
| | HornetUK | Stilo | 4 | 12-02-2005 20:38 |
| | fixitagaintomorrow | Cinquecento / Seicento | 0 | 31-12-2004 01:17 |
| | jasper | Stilo | 2 | 24-11-2004 19:16 |
| | minotour | Bravo / Brava | 1 | 10-10-2003 05:53 |
| | Neil Barker | Stilo | 3 | 24-04-2003 00:26 |
