The FIAT Forum
Old 28-12-2004   #1
Trader Rating: (0)
Unhappy Underheating!
I have had a problem with overheating, rad had been a little suspect for the past 6 months, eventually got around to changing it last week. After changing the rad my temperature when running stays around 70 degrees. There is an issue that I have had before and after the radiator change, when travelling at a constant 60-70 the heater goes cold. I have found a couple of ways to correct this. One is to stop and start the car again, the heater then will warm up once more. Or to stay stationary for a while and drive off again when the temp has increased to maybe 80 degrees. I think all of the air is out of the system, I have taken the expansion cap off a few times when hot and cold, have topped up the coolant a couple of times as a result. All of the hoses top and bottom on the rad and the heater feel warm / hot but the resulting air from the blower in the car is cold. There is a similar sympton when leaving the car idling after just starting on the drive, the heater will warm up and the temperature will climb to a maximum of 80 degrees, cannot get it anywhere near 90, the heater will go cold, then if you rev the engine, blipping the throttle a few times the temperature guage will plummet back to 60-70 degrees and the heater will warm up. Any ideas on where to check?
ShaggyDoo is offline
Old 28-12-2004   #2
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
Re: Underheating!
Have you used the two bleed screws to get all the air out of the system? There's one behind the driver's headlight and another at the back of the engine bay on top of one of the hoses which feed the heater.
Pete, Clubcento technical bod.
Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento
fixitagaintomorrow is offline
Old 28-12-2004   #3
Trader Rating: (0)
Re: Underheating!
Thanks for that...was wondering where the bleed screws are for these....
I will undo them tomorrow and see what happens.
Old 28-12-2004   #4
Drives a Punto
Trader Rating: (0)
joecinq has donated! Yemen
Re: Underheating!
Sorry if i havent read your question right, but are you not getting any hot air through the fan?
EDIT- i re-read it , and it sounds like you may have an airlock in your system.
My friend had something similar and he said that the car was under reading as there was an airlock where the sensor was. If that makes sense....
So like pete said, bleed it and re-fill to remove the air lock
3rd Fiat - luck as good as ever
joecinq is offline
Old 28-12-2004   #5
Trader Rating: (0)
Re: Underheating!
If that doesn't work, it could be a sticky thermostat.
Old 28-12-2004   #6
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: Underheating!
The temperature on the driveway problem is fairly common on 899 cars. The water pump will not circulate enough water at idle. The water in the engine becomes hot because it is not being pumped through the radiator, when you increase the revs, the pump increases the flow and the cool water enters the block.
D
rallycinq is offline
Old 29-12-2004   #7
paul_treg's Avatar
Trader Rating: (0)
Re: Underheating!
As "Fixitagaintomorrow" says, could be a stuck open thermostat, just had that problem on my 900s, new thermostat and all's well.
Fiat thermostats aren't that cheap mind, about £26 is quite a bit for one of these devices and that was a patern part not a Fiat part.
Paul T
Merry Christmas and a Happy New Year
paul_treg is offline
Old 29-12-2004   #8
Fat pigeon... APPLE!
JonnyBoy's Avatar
Trader Rating: (1)
JonnyBoy has donated! United Kingdom
Re: Underheating!
Aaaaaagh! £26?!?! My Punto's running cool at the mo, got to be the 'stat as I've flushed, refilled and bled the cooling system recently. It doesn't go much past 1/4 of the way up the temp gauge even after razzing it up the motorway for an hour; only way it heats up properly is when it's stood tickin over for ages (eg in kfc drive thru Q ). Bloody car! More expense!
Back in the day: mildly-modded Punto 55SX; rusty Ford Capri 2.0 Laser
Then: mk2 Focus Zetec Ti-VCT; same Capri, less rust
Now: Bravo Dynamic 150 MJet, in red, with extra toys same Capri, same rust
JonnyBoy is offline
Old 31-12-2004   #9
Ralf S.'s Avatar
Trader Rating: (0)
Talking Re: Underheating!
Each thermostat is a different price.. it depends how complicated the design is. Cheapest one I ever bought was for an Uno @ about a tenner.
Ralf S.
No bullets for chaingun
Ralf S. is offline
Old 31-12-2004   #10
JonnyBoy's Avatar
Trader Rating: (1)
Re: Underheating!
Just done my thermosplat, the part cost me a mere 11 squid from Motosave. The old one was fooked, it was stuck open (tested by blowing through it!), now the motor runs at halfway up the temp gauge like it should and the heater's actually hot
JonnyBoy is offline
(T) An underheating cinq? phil_harry Cinquecento / Seicento 8 17-11-2004 13:20
