The FIAT Forum
Old 18-12-2004   #1
Wah
Trader Rating: (0)
Geabox problems
Just about to start a 110 miles journey today, with my cinq fully laden with my stuff, when the gearbox decides to start playing up.
heres the problem. Driving down the road, get stuck at some lights. I try to pull away but it wont go into 1st. Finally get the thing in gear, change to second and then try for third, but nothing. cant even move it right. So no 3rd, 4th, 5th or reverse gears.
The RAC are on there way, 2 hours they tell me. In the meantime has anyone got any ideas if this is a simple or major problem.
Wah is offline
Old 18-12-2004   #2
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: Geabox problems
Should be very simple, a inkage ball cup will have fell off,hopefully. The linkage could be damaged or the gearbox itself, but most likely a connector.
Good luck
D
rallycinq is offline
Old 22-12-2004   #3
Wah
Trader Rating: (0)
Re: Geabox problems
My cinq is all sorted......hopefully. The problem was with some cables. My local garage said it would cost around 200 quid to get new cables and clips fitted, instead they reattached the old ones and screwed or welded them back into place.
Runs like a dream at the moment, so fingers crossed.
Wah is offline
Old 22-12-2004   #4
Principality Retained :)
Trader Rating: (3)
arseofbox has donated! United Kingdom
Re: Geabox problems
Welding those buggers sounds a bit hairy!
On the Sporting, they pop on at the G/B end (well, they need some encourgement with a small hammer!)
On the 899cc, one pop's on, the other one is secured by a circlip.
I dont think welding should be necessary, unless the gear lever end assembly broke, In which case, the usualy procedure would be to replace it!!!
arseofbox is offline
Old 22-12-2004   #5
Wah
Trader Rating: (0)
Re: Geabox problems
I think he mentioned something about the gearbox end. It only cost me 50 quid and i trust these guys there sound.
As long as the beast continues to run, I'm happy.
To justify what ive done, I only paid £340 for the car so spending over 200 quid on getting it fixed defeats the purpose of buying a cheap run around.
Wah is offline
Old 22-12-2004   #6
Trader Rating: (3)
Re: Geabox problems
Excellent...makes sense that!
(T) problems problems problems...... Mulge Punto 39 06-04-2006 00:29
(T) problems problems problems :confused: red_cinqo Cinquecento / Seicento 13 29-09-2004 17:49
(T) Punto 55 S, what have I bought (problems) belgrade_punto Punto 9 08-02-2004 03:16
Problems with car + Warrenty...please help! Sando Lets Talk FIAT 6 06-09-2003 02:57
(T) Problems and warrenty...please heeeeeeelp! Sando Cinquecento / Seicento 0 05-09-2003 14:25
