| An underheating cinq? Hi, read the sticky on overheating cinqs, but mine stays rock bottom at about 50 degrees when i am driving around, and in heavy traffic it goes up to about 90 degrees. should it be this low? 50 degrees when cruising on the motorway? Am confused as my uno ran at about 90-95 degrees all the time, and that had a FIRE engine too.
__________________ Ex 1989 Champagne Fiat Uno 45 "Breeze" Ex 1995 Red Cinquecento Sporting 2000 Mercedes A160 Avantgarde | |||
| Banned | Re: An underheating cinq? ur lucky heh ur radiator must actually work
| | #3 | ||
| Re: An underheating cinq? mine does the same, hardly ever goes to 90 degrees, while D4NS cinq seems to always be at about 90 degrees
| | #4 | ||
| mad bad and very very old | Re: An underheating cinq? Two points. 1) Its only a guage, and a fairly cheap one at that. 2) Don't be confused, on the motorway the airflow through the radiator will keep the engine cool even though its being driven hard. Remedy:- Thermostat could be jammed open, time to replace. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #5 | ||
| Re: An underheating cinq? Charlie overheated horrendously when I first got him. New rad and stat now in and he sits quite happily at about 75 degrees on the motorway. Sat in traffic it creeps up to just over 90. Fan usually kicks in and keeps it stable though. I wouldn't worry too much, although as suggested above the stat might need to be checked
__________________ ~~~~~~~~~~~~~~~~~~~~~~~~ Carla, Minty & Harvey!! | |||
| | #6 | ||
| Re: An underheating cinq? When i got my radiator it stayed very low for a few months hardley ever had the fan running. Now will go to 90 when stood in traffic but rad over a year old now so will probably have a load of **** in it
__________________ | |||
| | #7 | ||
| Re: An underheating cinq? My car was like that when i got it, in the end i solved the problem, it had no thermostat
__________________ Praise the pimped cinqo | |||
| | #8 | ||
| hi friends :waves: | Re: An underheating cinq? Try re-bleeding the system mate, can you get heat from the heater? Liam
__________________ CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S 97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND | ||
| | #9 | ||
| Re: An underheating cinq? Thanks people, have checked out my radiator, looks brand new, all the fins on and not rusty. Plenty of coolant and you can get heat from the heater after a few minutes. after a while fan cuts in and out every minute or so when its idling. Think i will leave it alone, maybe like you say the gauge is crap. Just a little worried as on previous fiats i have owned the temperture guage has to be watched more closely than the speedo sometimes!
| | peaster2k | Cinquecento / Seicento | 26 | 01-03-2004 07:25 |
