| nippy little runt | rear lights hello all, need to pick your electrial brains.. i replaced my rear right night bulb.. the other one was blown.. for some reason, the light does not work... but the brake does.. so assume the fuse is fine or the brakes light will not come on. The rear lights are the same as brakes but the rear lights dont come on... what can the problem be...? fuse ok.. the other light works... i need help! David
| Moderation in Moderation | Re: rear lights possibly a dodgy ground, or a dodgy bulb holder (dodgy wiring)
__________________ Lots of mods Rev1 MR2 Turbo - Sold pending collection RX7 Twin Turbo - Because real men play with twins | ||
| | #3 | ||
| Re: rear lights Your explanation is well dodgy but from what your saying basically one bulb does two jobs. It is a tail light and a brake light ie there is two filaments in each bulb. Therefore it is possible to just blow one filament leaving in your case the brakes working and the tail lights out ok
__________________ | |||
| | #4 | ||
| nippy little runt | Re: rear lights yes... my explaination.... i replaced the bulb at the back for lights and the brake lights works as one... so the bulb is new... brakes work but back light does not.. cheers David.
| | #5 | ||
| Moderation in Moderation | Re: rear lights did you definately get a twin filament bulb?
| | #6 | ||
| Re: rear lights [quote=microcar]yes... my explaination.... i replaced the bulb at the back for lights and the brake lights works as one... so the bulb is new... brakes work but back light does not.. QUOTE] Can you write in english???
| | #7 | ||
| nippy little runt | Re: rear lights lol cheers motor world chink... your right, my english is bad... much like your explanation.. lol. cheers for your positive feedback...
| | #8 | ||
| Re: rear lights David, check the filaments, if the're both OK the most likely cause is the bulb holder, have a look to see if the contacts are dirty or corroded, check that the bulb goes in OK and that when it locates on the pins there is pressure from the contacts in the holder. You may have to bend the holders up a little to ensure good contact. If this doesn't work its best to get a meter on the holder to see if there is any current. Hope this helps. michael
__________________ Michael, Developer of the mckcrich chip - more power per £ than any other mod you can buy for your cento (or punto) | |||
| | #10 | ||
| nippy little runt | Re: rear lights cheers Mick and all... i think it could be my connections.. will let you all know..
| | #11 | ||
| hi friends :waves: | Re: rear lights Does the other side work ok? Liam
__________________ CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S 97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND | ||
| | #12 | ||
| nippy little runt | Re: rear lights Yes it does work on the left side... the bulbs are new so umm... need to prod around to find the root...
| | Body Stylist | Punto | 30 | 09-04-2005 17:02 |
| | Neofolis | Stilo | 26 | 12-10-2004 23:43 |
| | thefishdude | Punto | 7 | 08-01-2004 22:07 |
| | mrpie | Stilo | 6 | 03-12-2003 05:31 |
| | mad_colm | Bravo / Brava | 6 | 30-11-2003 18:18 |
