The FIAT Forum
Old 04-11-2004   #1
jimmy's Avatar
Trader Rating: (0)
Question brakes! i think?
hi guys can anyone help me with my brakes when the car is slowly rowling in traffic or whatever reason theres an sound like the brake pads on the passenger side are slightly holding onto the disc? its like a woooing noise that echos through the metal any ideas what the problem is?
Black /F/I/A/T/ Seicento 15" Wolfrace Octanes 3" s/s Peco Exhaust Few Holes Drilled In The Airbox And Drilled And Grooved Brake Discs
jimmy is offline
Old 04-11-2004   #2
Italians do it better :P
Trader Rating: (1)
Alfie has donated! Italy
Re: brakes! i think?
sounds like it might be the wheel bearing to me...
if so youl find that when you turn corners it will start getting louder...
check it by jacking up the wheel and first put one hand on the bottom and one on the top of the tyre and rock the wheel and look for any movement..
im crap at explaining stuff... maybe someone else will explain better.. a pic would explain it loads better
but anyways.. its the 1st thing it check as it takes minutes... and its free!
2000 X Seicento Sporting, Yellow 1108, 2004 54 Punto Van, White 1.3 16v MultiJet
muore la pecora muore l'agnello muore la gente piena di guai... ma i ROMPI COGLIONI non muoiono mai!
Originally Posted by binki
i had a AppleSei once worse hump i ever had
Alfie is offline
Old 04-11-2004   #3
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
easy way to tell is if the sound goes away (or is quieter) when you turn a corner.either left or right depending on which bearing it is,does sound like a bearing though.
custard is offline
Old 04-11-2004   #4
polecat's Avatar
Trader Rating: (0)
polecat has donated! United Kingdom
You could also have some dirt on the brake pads. This can make noises ranging from a low "Wooo" to a high pitched scream. When driving with the noise present, press the brake pedal very slightly and see if the noise goes away. If it does, and the pads are not worn, then it will usually burn off in a couple of hundred miles. Not much else you can do, other than sanding or replacing the pads.
Check bearings at the same time as mentioned above.
polecat is offline
Old 05-11-2004   #5
jimmy's Avatar
Trader Rating: (0)
Talking Re: brakes! i think?
yeah the noise goes away when i press the brakes but my bro in law changed the front and rear brakes about 2 months and i do about 1300 miles a month maybe the problem would have burnt away buy know
also;
when i reverse on full lock the car makes a grinding noise (only noticed after posting message) so it must be the bearing yeh?
sorry if im talking s&$t but im a bit drunk
jimmy is offline
Old 05-11-2004   #6
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
grinding noise? from the front? engne mounts?
arc is offline
Old 05-11-2004   #7
jimmy's Avatar
Trader Rating: (0)
they werent done long ago either but i do drop the box a lot due to the lack of 2-3k rpm its not as bad as it used to be
with induction kit its better but it needs booting from time to time
jimmy is offline
Old 05-11-2004   #8
hi friends :waves:
Liam's Avatar
Trader Rating: (0)
Liam has donated! United Kingdom
Could be CV joint too but not likely, gearbox mount yeah maybe.
Bearings more likley to go on the rear.
Liam
CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline
(T) brakes Diesel20 Stilo 11 11-05-2004 19:06
(T) Disc brakes on punto from Tipo or Bravo HGT Davey1 Punto 6 09-04-2004 16:10
(T) brakes...... again oliverschepisi Punto 1 05-02-2004 02:56
(G) AHHH my brakes dont work! Bushboy Uno 6 13-11-2003 23:58
(T) Brakes, brakes, brakes my cinq now Cinquecento / Seicento 10 17-10-2003 19:33
