| Hi, I've just got into work after failing to get my car started... It's been working fine all day but has decided that it didnt want to do the journey to work. Basically everything is fine until I try to start the car... I can turn the ignition on and all the electrics come on.. (I believe I can even hear the fuel pump come on). The problem is when I turn the key all the way. As soon as I try to start the car nothing happens, and literally everything goes off. All the dash lights, my radio and clock etc... I can turn the ignition off and on again and I get the lights back, but again when I try to start everything just switches off, and nothing happens.... Has anyone got any idea what this could be? I desperatly need my car to get to Uni and back.. esp as I have exams this week Any help appreciated. I've tried turning everything off.. lights etc, but no joy. And I didnt notice any other lights coming on on the dash. Thanks Adam
| Moderation in Moderation | Re: Urgent Electrical Help Plz. did the clock reset itself when u tried to start the engine? sounds like a dodgy earth possibly?
__________________ Lots of mods Rev1 MR2 Turbo - Sold pending collection RX7 Twin Turbo - Because real men play with twins | ||
| | #3 | ||
| Re: Urgent Electrical Help Plz. I don't think the clock did reset completely... but my alarm did beep as if it had lost its power... The Earth for that is connected to the steering column. Perhaps the power didnt go off long enough for the clock to reset... I don't know
| | #4 | ||
| hi friends :waves: | Re: Urgent Electrical Help Plz. Defo electrical then, eh sounds like a flat battery but could be wrong. Have you tried a jump? Liam
__________________ CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S 97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND | ||
| | #5 | ||
| Re: Urgent Electrical Help Plz. Just got back from work... Tried to start it... It started straight away, no problem.... Don't think it could have been a flat battery, I've used it to drive over 30miles today, so battery should be nicely charged... I just hope it doesnt happen again when there's no one about to give me a lift.
| | #6 | ||
| Re: Urgent Electrical Help Plz. Starter Motor almost defo
__________________ | |||
| | #7 | ||
| Re: Urgent Electrical Help Plz. Yeah I agree with MWC. Sounds like the starter is jamming. You would get all electrics working until you try to turn the starter, then if it sticks it takes all the power and so it seems like everything else is dead. | |||
| | #8 | ||
| Re: Urgent Electrical Help Plz. Oh dear... How come it started when I tried it several hours later?.... I'll go see if it starts now... Is there a way to stop it jamming? Oiling it? or something...
| | #9 | ||
| this is where i stand | Re: Urgent Electrical Help Plz. if it refuses to turn, hitting it will free it, but then it'll lock again next time most likely. you need a new one, but hitting it will help for now
| | #10 | ||
| Re: Urgent Electrical Help Plz. happend t me the alram wasnt fitted correctly t the battery and kept drainning it i ended taking teh battery out an refitting it again since then ive no other problems
| | #11 | ||
| Re: Urgent Electrical Help Plz. Agree with above. Sounds like starter. Carry a hammer or something similar to hit it. Had to do the same with one of my old Stradas years ago. Quick whack with the hammer and the car was fine. Did you try bump starting it when it wouldn't start?
__________________ ~~~~~~~~~~~~~~~~~~~~~~~~ Carla, Minty & Harvey!! | |||
| | #12 | ||
| Re: Urgent Electrical Help Plz. Ok... My car's done it again.... It seem like the power is completely drained.... When I turn on the ignition all the lights are dim and if I turn my radio on the power keeps cutting out... The clock itself doesnt loose the time though.... :| I didnt have my tools with me... I'm gonna test the battery voltage tomorrow and have a look at the starter motor.... Has anyone got any other ideas? Also where abouts is the starter motor? Thanks
| | #13 | ||
| Re: Urgent Electrical Help Plz. Update on the situation.... I managed to get my car started this morning... It needed a jump start because the battery was at 9V... It started straight away using my friends battery.. I left it idling for a minute or so, and turned all my lights/heater/etc on... Battery was running at 13-14V... I turned my car off and my radio went off with it (it's powered by constant live so shouldnt go off) and tried to start it again... and as I thought, it didn't start. So I jump started again to get my car home... So, at the moment, my car is sitting in my garage refusing to start again. If I put a multimeter on the battery I can see the voltage steadily decreasing... At the moment it's about 10.38V, if you wait 10secs or so it goes down to 10.37... 10.36 etc... I'm not sure what to do now... Would it still be the starter motor or the battery? The green light is on the battery, so it thinks that it is fine... Any help would be greatly appreciated!
| | #14 | ||
| Cento Boy | Re: Urgent Electrical Help Plz. test all you earth points and alternator. That's all i can think of
__________________ Sie - Proud advocate of Centoism Cinquecento60 Clubcento - The UK Cinquecento and Seicento Owners Club Clubcento Forum | ||
| | #15 | ||
| Re: Urgent Electrical Help Plz. Definitely duff battery. Sounds like the alternator is OK as the charge is high whilst running but the battery will not maintain charge whilst not in use, if you are lucky it may need topping up with distilled water and recharging, but probably be better getting a new one (the problem will be worse the colder the weather gets).
__________________ 'EckyThump! | |||
| | Dunc Maclean | Uno | 14 | 25-03-2005 14:07 |
| | nick_K | Cinquecento / Seicento | 10 | 21-10-2004 14:00 |
| | mathisj7 | Marea | 2 | 07-06-2004 04:14 |
| electrical prolems | racsoton | Tipo | 5 | 10-03-2004 16:50 |
| | ginjaninja | Marea | 0 | 19-10-2003 19:08 |
