The FIAT Forum
Old 19-10-2004   #1
Principality Retained :)
Trader Rating: (3)
arseofbox has donated! United Kingdom
Maximum Compression?
Right, after hearing that I can boost the power by changing the CR, Ive been thinking:
A. Raising the CR means charge temp is going to be higher so it will inevitably preignite - but this can be solved so is no major deal.
B. The raised temperature means a higher likelyhood of melting pistons etc...
So with this in mind, whats the highest CR I could use without making engine conditions too warm? Is 11:1 too high? I suppose If I burretted the head I could actually calculate that...or, has anyone already done it?
arseofbox is offline
Old 20-10-2004   #2
hi friends :waves:
Liam's Avatar
Trader Rating: (0)
Liam has donated! United Kingdom
Re: Maximum Compression?
Do you plan to cure the pre ignition by retardign the timing?
Liam
CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline
Old 20-10-2004   #3
Trader Rating: (3)
Nope...using a higher octane fuel.
Old 20-10-2004   #4
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
at £4.00 per litre!!, you are completely barking
D
rallycinq is offline
Old 20-10-2004   #5
The Negotiator's Avatar
Trader Rating: (0)
The Negotiator has donated! United Kingdom
He probably means optimax.
Now drives: '52 Megane 1.9dCi
Past:
Y-reg Fiat Brava JTD (Pale Blue) (2006)
M-reg UNO (2003-2004)
'51 Fiat Brava 80 SX (black) (2006)
The Negotiator is offline
Old 20-10-2004   #6
Trader Rating: (3)
Yeah...Optimax /98 RON fuel is something like that...
Wasnt thinking 110RON racing fuel... Cant source that easily let alone afford it!!
Old 01-10-2006   #7
Italian Coke Can's Avatar
Trader Rating: (0)
Digging up an old thread, but....
Doing the head gasket on my cinq 1.1 this week. Getting the head skimmed.
Question is - how much is enough to take off and how much *can* i take off in respect to raising the CR?
Played with the CR and squish bands in bike engines, but these car things are new...
Italian Coke Can is offline
Old 01-10-2006   #8
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
the head has a marking on it for the max skimming allowed if thats any help
custard is offline
Old 01-10-2006   #9
Trader Rating: (0)
is a bit more complicated then just asking what cr you can run on an engine, there is alot more that come into play eg cam for a start, the only real way of finding out is to find out what they use on say race engine, but most the time there are rules in racing that dont allow a lot of stuff or try it and see, you can always put lots of octane booster in if it does pink which it prod will. or use avgas but your not allowed to us that on the road
nogin is offline
Old 02-10-2006   #10
Trader Rating: (0)
Oldschool has donated!
You can go over this mark by at least 0.25mm. Also you can take about 0.5mm off the block or alternatively use the new metal gasket Fiat supplies now using the 886 cam.
If you are willing to pocket the pistons a bit deeper than standard you can skim even more off the head.
Only drawback is if you go over the maximum skimming marks you will get into problems with the standard belt tensioner and it would be advisable to use a vernier pulley.
Oldschool is offline
Old 02-10-2006   #11
Moderation in Moderation
GhostWKD's Avatar
Trader Rating: (0)
GhostWKD has donated! United Kingdom
also isnt the max marking the point at which the non interfierence charecteristic of the FIRE engine is at risk? as if you skim past this that could be a risk? (in theory, i dont know for sure)
Lots of mods Rev1 MR2 Turbo - Sold pending collection
RX7 Twin Turbo - Because real men play with twins
GhostWKD is offline
Old 04-10-2006   #12
Trader Rating: (3)
Most probably. It'd seem to be the most sensible explanation IMO
Old 04-10-2006   #13
Asteris's Avatar
Trader Rating: (0)
Greece
DO NOT AND I MEAN DO NOT skim the head. Use the 0.6mm metal gasket from the new Grande Punto instead...
Asteris is offline
Old 04-10-2006   #14
Trader Rating: (3)
Why not?
Old 04-10-2006   #15
Asteris's Avatar
Trader Rating: (0)
Greece
Because metal headgasket is thinner and more durable. Fat headgaskets are more prone to failure...
Asteris is offline
rally strata fiatman Other Fiats 8 24-01-2005 19:34
Compression failure. Morty Mort Lets Talk FIAT 25 12-07-2004 23:49
(T) Compression on Mk2 Sporting??? igorpetkovski Punto 2 08-04-2004 01:24
(S) Maximum wheel size for Mk2 Punto nawtwrong Punto 12 05-04-2004 02:33
