| i got a huge problem need help need car for tomorrow some things gone down i now have no front brakes just rear any ideas gett back asap thanks chris
__________________ Chris | |||
| mad bad and very very old | Re: brakes help asap The brakes are split diagonally, so you can't have lost just the fronts, in theory. What state are the pads in?, are the calipers moving OK? Get back to me Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #3 | ||
| Re: brakes help asap well at first i thought it was the pads but i change them but still no joy also blead the brakes could it be the brake servo thats my last idea please get back
| | #4 | ||
| mad bad and very very old | Re: brakes help asap Did you check the calipers are moving OK. If you have fitted new pads and the caliper is stuck then that would cause a problem. Is the pedal hard, or does it go to the floor? Cheers D
| | #5 | ||
| Re: brakes help asap your problems sound simular to mine, little or no front brakes and having to pump to stop hard i replaced the servo and M/C with 1 from a scrappy, replacing the servo and M/C is a right pain, the gearbox is in the way, but lots of kicking a screaming gets it in... i'm hoping for you that it isnt that.
__________________ Fix the fiat so its at ok'ish working condition, Sell it off to some1, Then by another fiat with twice as many problems as the first 1. Its the fiat life for me. | |||
| Brakes failure | Dean062 | Multipla | 10 | 10-08-2006 12:26 |
| | Diesel20 | Stilo | 11 | 11-05-2004 19:06 |
| | Davey1 | Punto | 6 | 09-04-2004 16:10 |
| | Bushboy | Uno | 6 | 13-11-2003 23:58 |
| | my cinq now | Cinquecento / Seicento | 10 | 17-10-2003 19:33 |
