The FIAT Forum
Old 06-09-2008   #1
Trader Rating: (0)
Seicento headlights are dim
My 2001 Seicento headlights are really dim - I actually thought they weren't working at all the other night!! Indicator and sidelights are all fine, but the main ones are dim. If I switch to full beam, they're only about as bright as they should be when dipped. If I try to adjust the dip, it doesn't seem to be doing anything. This is a pretty recent problem, they were fine a month ago. Last MOT was February.
I did a quick board search but I'm not sure I found the same problem. They do work, just not very brightly! Do you think it could be electrics, or the bulbs, or something else? And any idea how much it might cost to fix...?
Thank you very much in advance!
miriam is offline
Old 06-09-2008   #2
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
Re: Seicento headlights are dim
change the bulbs not an expensive fix, couple of quid for the bulbs
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
The following user says "Thank You!" to AppleSei for this useful post:
miriam (06-09-2008)
Old 06-09-2008   #3
olgit's Avatar
Trader Rating: (0)
I have the same problem with my cinq sporting I even put uprated bulbs in whitch alegerly are not street leagel as siad on the bulb packaging but its still like a victorian gas lamp and I had the electrics checked and its showing normal power output maybe its just a Fiat thing,even my son's mopeds got brighter lights, I thought I was the only one with problem
BMXers are not all chavs
but some are on medication
olgit is offline
Old 06-09-2008   #4
Brooky's Avatar
Trader Rating: (1)
get some spot lights
16v cinq with ITB's
Brooky is offline
Old 06-09-2008   #5
olgit's Avatar
Trader Rating: (0)
Or strap my sons moped on the roof
olgit is offline
Old 06-09-2008   #6
Italian Coke Can's Avatar
Trader Rating: (0)
when i first got my cinq i thought the lights were awful. Then i realised i was driving on side lights all the time . . .
Italian Coke Can is offline
Old 06-09-2008   #7
olgit's Avatar
Trader Rating: (0)
And I thought I done silly things
olgit is offline
Old 06-09-2008   #8
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
It's worthwhile carefully pulling the connectors off and cleaning them, then popping some vaseline in. I've seen headlight connectors where the contact was so bad the whole of the plastic around the connectors had melted.
Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes!
fingers99 is offline
The following user says "Thank You!" to fingers99 for this useful post:
miriam (06-09-2008)
Old 07-09-2008   #9
Trader Rating: (2)
ycming has donated! United Kingdom
hmm i had a difference experienece, i always felt the cinq headlight was pretty good!
Ming
Wanted : Nothing at the moment
ycming is offline
Old 09-09-2008   #10
Ralf S.'s Avatar
Trader Rating: (0)
The Cinq doesn't have a separate side-light bulb; it passes a lower voltage through the main bulb to give you "sidelights". Seic' must be the same.
This setup needs some kind of electrickery-pokery to manage.. like a regulator/rectifier.. and yours is probably Fubar'd.
First of all check that the bulb actually switches to a brighter output when you put the dipped beams on (rather than sidelights). If it doesn't, there's a problem.
High Beam is a different plate of pasta, as it has a separate circuit.. but side and dipped is controlled by a "box" somewhere using the same circuit. The box (a relay?) is probably the culprit.
Ralf S.
No bullets for chaingun
Ralf S. is offline
Old 09-09-2008   #11
fingers99's Avatar
Trader Rating: (1)
This is wrong. The Cinq does have a seperate side light: there's a picture of a Cinq headlight shell in my gallery.
The white blobby bit is the sidelight holder.
But some Cinqs (maybe early Seis, too) have a dim-dip arrangement as well.
Relays tend to either work or not: if there's voltage at the connector (and in this case there must be) then the relay isn't going to be the issue.
Old 10-09-2008   #12
Ralf S.'s Avatar
Trader Rating: (0)
Mine hasn't.. or at least.. I didn't see one!
When my dipped beam in the bulb died, so did the sidelight. When I replaced the main bulb, the sidelight started working again..
So... I dunno!
Ralf S.
Ralf S. is offline
Old 10-09-2008   #13
SuicideUK's Avatar
Trader Rating: (0)
I've replaced the sidelights and the main headlights...and they're still pretty dim! On a road with street light I can't even see my ice blue bulbs
Luke.
Total n00b
SuicideUK is offline
Old 10-09-2008   #14
darren636's Avatar
Trader Rating: (0)
my sei and cinq lights are poor.... thank the lord for spots!
they cut my stopen!?!
darren636 is offline
Old 10-09-2008   #15
olgit's Avatar
Trader Rating: (0)
Luke.
Done the same got the same effect as you did
as for the side light thing my cinq has them I found the the bulb holders
disconnect hanging from the back of the headlight without bulbs in
put some in n they worked still crap though
olgit is offline
(S) Seicento alternative headlights? Mr.Steps Cinquecento / Seicento 14 29-01-2008 16:18
(G) dim lights Chris-blk2000punto Punto 7 21-11-2007 01:05
(G) Headlights Dim when i put my foot down? :S chris_VW_1987 Punto 12 25-05-2007 02:22
(G) help batry light still dim ivor Cinquecento / Seicento 2 11-02-2007 19:39
(T) dim headlight shaliru Punto 6 16-02-2006 14:03
