The FIAT Forum
Old 04-09-2008   #1
crispyduck's Avatar
Trader Rating: (0)
head gasket gone?
Hello lovlies,
I wonder if you could help me please. I was searching through the forum and i saw a post about the cinquecento with the misfiring cylinder and losing water from the resevoir which eventually was found to be corrosion on the cylinder and leakage into the combustion chamber.
Basically, my car has started to lose water in the resevoir rapidly after every drive and seems to have air in it. I put K Seal in it but to no avail and im pretty sure that when i start it from cold i'm pretty sure it's misfiring a bit.
I am a complete novice when it comes to cars and apart from the general upkeep of mine i have no clue (although i really really want to learn and am starting to), but please what would be your advice to me. Would i be able to fix a problem like this myself or do i need to take it in. Is it relatively easy/cheap?
thanks so much in advance x
crispyduck is offline
Old 04-09-2008   #2
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: head gasket gone?
First thing to do is make sure it really is the head gasket. Get a garage to do a coolant pressurisation and/or compression test (or do the compression test yourself).
Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes!
fingers99 is offline
Old 04-09-2008   #3
darren636's Avatar
Trader Rating: (0)
a garage is gonna want £200 plus to fix a head gasket. so make sure you get it diagnosed properly. hg's are a pain but not too difficult to fix.
they cut my stopen!?!
darren636 is offline
Old 05-09-2008   #4
Get a wriggle on!
levemir's Avatar
Trader Rating: (0)
levemir has donated! United Kingdom
a slight misfire could also be a plug lead breaking down, if they have not been disturbed for a very long time then they are quite cheap to replace.
levemir is offline
Old 05-09-2008   #5
Yazza54's Avatar
Trader Rating: (0)
Originally Posted by crispyduck View Post
Hello lovlies,
i like your pic
Yellow Stilo 1.6 16v Dynamic 3dr -Remapped - Konis all round - OMP Strut Brace - Full Longlife Stainless Cat-Back - GSR Induction Kitted - Mudflaps.
Yazza54 is offline
Old 05-09-2008   #6
bravachris's Avatar
Trader Rating: (0)
fill it with water and leave the resevoir cap of then start the engine and give it a good steady rev if the water bubbles up and rises then its usualy the head gasket but get a second opinion
bravachris is offline
Old 09-09-2008   #7
Ralf S.'s Avatar
Trader Rating: (0)
Here's a second opinion.. "It's the head gasket".
It's an easy one to fix, if you are handy with the spanners.. Fit a new cam-belt and tensioner too, so you don't have to do that again for a few years.
Ralf S.
No bullets for chaingun
Ralf S. is offline
Old 09-09-2008   #8
Yazza54's Avatar
Trader Rating: (0)
Hello lovlies,
Nice pic
Yazza54 is offline
Old 09-09-2008   #9
FIREsporting's Avatar
Trader Rating: (0)
FIREsporting has donated! United Kingdom
Ralf S.
new cam belt and tensioner i do the water pump to
FIREsporting is offline
Old 09-09-2008   #10
Yazza54's Avatar
Trader Rating: (0)
Hello lovlies,
I do like that avatar pic
Yazza54 is offline
(G) Head gasket? luisacl Bravo / Brava 21 27-05-2008 09:54
(T) Oil Leak (Rocker gasket or head gasket???) stayinfly Punto 26 12-04-2008 22:23
(T) Head Gasket anth Punto 0 13-03-2008 20:25
(G) punto 16v head gasket head problems philmoore Punto 6 11-03-2008 19:36
