The FIAT Forum
Old 04-09-2008   #1
Lets Get Dangerous!
Benjammo's Avatar
Trader Rating: (0)
Benjammo has donated! United Kingdom
Are these worth 101 quid?
My seicento sportings handling like a jumper my nan's nitted, so i think need some new bushes but I don't know much about this sort of thing. the general handling's really gone down hill, it sways and drifts really bad, theres also a knocking from the rear, I'm pritty sure its either down to a worn bush or a buggered shock absorber. would these sort the problem or could the problem be something worse? also would standard bushes be worth buying insted?
Thanks ya'll
Benjammo is offline
Old 04-09-2008   #2
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: Are these worth 101 quid?
Generally, orrible handling can be down to knackered bushes (knocking from back or front), top mounts (squeaking or knocking from the front) or buggered shocks (check for oil misting).
You didn't post the link, so I can't be absolutely sure what you're refering to.
Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes!
fingers99 is online now
Old 04-09-2008   #3
Lets Get Dangerous!
Benjammo's Avatar
Trader Rating: (0)
Benjammo is offline
Old 04-09-2008   #4
fingers99's Avatar
Trader Rating: (1)
They are worthwhile. At the back they're easier to fit than the stock ones (which FIAT won't sell you, but can be obtained from you know who).
Price seems OK, but best do a comparison.
Old 04-09-2008   #5
Trader Rating: (3)
on a side note I think I've worked out a way to remove the old bushes without risking any weakening off the trailing arms. I've just got to turn down a piece of steel to the right dia before trying this.
GoBe is offline
Old 04-09-2008   #6
umop apisdn
balidey's Avatar
Trader Rating: (1)
balidey has donated! United Kingdom
I bought my rear powerflex bushes from Fluffy the Impaler. Were much cheaper than all the other places I tried. (not advertising, just stating fact)
I like the bit in that auction link 'No special tools are needed to fit' makes it sound like its an 'easy' swap
Your sister is hot, but your mum does that thing with her tongue
balidey is offline
Old 04-09-2008   #7
Funny saying here
jamie86's Avatar
Trader Rating: (1)
jamie86 has donated! United Kingdom
Bushes are a consumable item on a car that normally get neglected by most drivers
The powerflex ones are definately the ones I would go with over standard Fiat items although price could dictate the choice
Also have you had a look to check yours are definately worn and that it's not something else? Eg check shocks aren;t leaking and the springs are in good condition?
Also what suspension set up are you running?
Originally Posted by A wise person
Mini invented the giant killer, VW started the genre, Ford & Vauxhall Desecrated it, but the Peugeot 205 GTi was undoubtedly the king of the breed.
jamie86 is offline
Old 04-09-2008   #8
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
Ditto, cheaper than from Powerflex themselves!
They don't need special tools to fit the rears.. just to remove the old ones. Sure you need a press for the fronts though
arc is online now
Old 04-09-2008   #9
Lets Get Dangerous!
Benjammo's Avatar
Trader Rating: (0)
I need to get the back of the car in the air really, its all standard sporting sus, i changed the front shocks last year for gass struts, sound cool going over bumps, I think i'll get a pair for the back too. I've never had to change the bush's so I've not got a clue fhat to expect. Still I'll give it a go. how ard can it be
Benjammo is offline
Old 04-09-2008   #10
Brooky's Avatar
Trader Rating: (1)
I got a full set for £50
16v cinq with ITB's
Brooky is offline
Old 04-09-2008   #11
Lets Get Dangerous!
Benjammo's Avatar
Trader Rating: (0)
where did you manage that one? I'll give you 55 for them
Benjammo is offline
Old 04-09-2008   #12
Brooky's Avatar
Trader Rating: (1)
From the classifieds, off yoda. There getting fitted to me project, so its a no to £55
16v cinq with ITB's
Brooky is offline
Old 04-09-2008   #13
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Explain please
Ta PD
rallycinq is offline
Old 04-09-2008   #14
Italian Coke Can's Avatar
Trader Rating: (0)
Got a full set on mine. About £50 each end, so you've foundd a normal price.
Rears were worth it as it'd would snake & Buck on fast corners. Harder to fit than the front.
Fronts were not really worth it. Fitted them and then the ball joints on the arms went so i had to buy new arms that come with new bushes already.
If you're going to the hassle of taking the arms off, replace them. In fact, save yoru money on the front and just buy new arms when needed.
Italian Coke Can is offline
Old 04-09-2008   #15
Lets Get Dangerous!
Benjammo's Avatar
Trader Rating: (0)
Originally Posted by rallycinq View Post
Explain please
Ta PD
the oil filled ones were just normal shockers, the gas ones have a pisssss sound when you hit a bump. I didn't know there were 2 types, the gas ones shuld have been more but they sent the wrong ones so they said.
I have no idea if there really is a diffrence but they do make a noise.
Benjammo is offline
(T) Stilo Multiwagon - 101,000 Mile Service markduncan100 Stilo 2 23-03-2008 13:48
(G) I just spent 35 quid on.... JimMagill 500 23 23-02-2008 20:05
speeding at 101 coyle Leisure Lounge 65 30-08-2007 12:47
101 pandafan Panda (Classic) 44 03-08-2006 12:09
101 more things removed from the human body custard Leisure Lounge 14 28-05-2006 12:12
