| | #16 | |||||
| Lets Get Dangerous! | Re: Are these worth 101 quid?
| | #17 | |||
__________________ Wanted : Nothing at the moment | ||||
| | #18 | ||
| mad bad and very very old | Re: Are these worth 101 quid? There is a small amount of education needed. 'Gas' dampers do not just contain gas. All types of dampers have oil being forced through valves as the method of damping. In a normal damper the space above the oil is filled by air. In a gas damper this space is filled by an inert gas. There is no difference until things get really hot. At that point in an air filled damper the air will mix with the oil and the oil will not damp as effectively as before. The inert gas in a gas damper will not mix with the oil so the damping remains more constant over a greater heat cycle. Usually damper manufacturers change the valving on a gas damper as they expect it to be used for more 'sporting' applications than a standard damper. I hope your gas dampers have a concertina rubber over the damper rod, and its that that is making the 'pith' sound Regards David
__________________ If it has pistons or tits, its going to be expensive. | ||
| The following user says "Thank You!" to rallycinq for this useful post: | ||
jamie86 (05-09-2008) | ||
| | markduncan100 | Stilo | 2 | 23-03-2008 13:48 |
| | JimMagill | 500 | 23 | 23-02-2008 20:05 |
| speeding at 101 | coyle | Leisure Lounge | 65 | 30-08-2007 12:47 |
| 101 | pandafan | Panda (Classic) | 44 | 03-08-2006 12:09 |
| 101 more things removed from the human body | custard | Leisure Lounge | 14 | 28-05-2006 12:12 |
