| Cinquecento (20/04/1994) leaking fuel Hello. Our car has very recently started dripping fuel when the tank is roughly over 3/4 full. The tank itself does not appear to be leaking but someone has told me that because the height of the top of the fuel tank is not far below the height of where the petrol cap is, that there is some sort of mechanism that should stop fuel flowing back through the overspill pipe and that this mechanism may have failed. I'm afraid I'm not at all technical but I've done my best to explain the problem !!!. Can anyone with knowledge of Cinquecentos of this period help please ???.
| mad bad and very very old | Re: Cinquecento (20/04/1994) leaking fuel Short of using 'tenacento' The pipes that run up to the filter pass through the inner sill just behind the drivers door, is that where your leak is? Cheers PD
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #3 | |||||
Cheers, Mark
| | Jetsfan5 | Cinquecento / Seicento | 4 | 05-04-2006 17:27 |
| | AIJ29 | Cinquecento / Seicento | 3 | 24-01-2006 19:11 |
| Fiat Tipo 1.4 ie 1994 fuel pump problem | StressPuppy | Tipo | 13 | 03-07-2005 04:52 |
| Fiat Cinquecento L Reg 1994 | Liam | Auction Watch | 7 | 05-12-2004 22:34 |
