| hi all, my cousin has just bout a t reg seicento sporting but once we had it home we noticed a couple of things. p.s. it has been stood for couple of months! 1.it is fitted with abs which u rarely see but even though the abs light comes on and goes off as normal, compared to my non abs sei the brakes seem awful. 2.the airbag light doesnt come on when the ignition first comes on so i believe there maybe a fault there or maybe the bulb has blown cus as i thought, if there was a fault the light would stay on all the time maybe? 3.the power steering light doesnt come on either and there is no power steering whatsoever! ![]() ive checked the fuses and cant see a problem there, so i was wondering if anyone knew if a relay or anything else was rtesponsible for these systems as the abs thing is new to me and ive never had a p/s problem. any help would be very appreciated as he is very upset that he sold his previous car and really wanted this one only to find that it had problems plus forgot to add, i looked at the engine when he got it back and noticed a heater pipe had split from rubbing and so had the map sensor pipe ![]()
__________________ Guess who's back!!!! ![]() | |||
| custodian of imola blue | Re: new sei - abs prob,no airbag or p/s light! The ABS doesn't actually improve the braking (some people have removed it!) but I suspect the issue is with the condition of other parts of the system. For the PAS, check the maxi fuses behind the battery. The MPIs don't have -- or shouldn't have -- a MAP sensor pipe (the MAP sensor is on the plenum chamber). I wonder if it's the servo pipe that's fubared?
__________________ Magnex Zorst for Cinq Sporting for sale! See classifieds. Hurry -- may be last one in captivity! Also cheap 14" 6J wheels -- easy way to more grip and better brakes! | ||
| | #3 | ||
| Scandinavian Passion.... | Re: new sei - abs prob,no airbag or p/s light! 1) If you've got bad brakes then ABS won't make them perform any better, what you need to do is work out why the braking system isn't up to scratch and fix it. If it's been standing a while I'd be tempted to go for new discs/pads up front and renew the brake fluid, also you'll probablly want to give the rear drums a damn good service too. 2) You'll almost certainly have a mechanical airbag which doesn't have a light on the dash, iirc only the MK2 Sei's with the MPI engine (and PAS as standard) had an eletrical airbag. 3) PAS wasn't standard on the Mk1 Sei and in all honesty it doesn't need it, the steering is light enough unless you're trying to turn the wheel when stationary and that's a recipe for messed suspension up geometry. fingers, surely T is to early for an MPI Sei? I thought they started with late Vs?
__________________ Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit Last edited by StoneNewt; 01-09-2008 at 19:33. | ||
| | #4 | ||
| custodian of imola blue | Re: new sei - abs prob,no airbag or p/s light! Sorry -- I'm hopeless with registration letters. With a T it must be SPI, so it does have a MAP pipe.
| | #5 | |||
ill check the fuses behind the battery for the pas fuse but even without it it feels very heavy even when driving. if it does have an airbag system, does anyone know if there is a fuse/relay anywhere that could be blown/damaged?
__________________ Guess who's back!!!! ![]() | ||||
| | #6 | ||||||
EDIT: tried getting a photograph but couldn't get the camera into a useful position with enough light
__________________ Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit Last edited by StoneNewt; 01-09-2008 at 22:15. | ||||||
| | #7 | ||
| ONE HOT SEI | Re: new sei - abs prob,no airbag or p/s light! not speaking for all 98 t's but dont think it even came with air bags or abs mine never had either fitted unless it was an extra i never noticed just wanted too get out and drive the car lol | ||
| | #8 | |||
why would they fit an airbag steering wheel though if the car didnt have an airbag system fitted????
| | #9 | ||
| mad bad and very very old | Re: new sei - abs prob,no airbag or p/s light! It could just be the rugby ball wheel without the airbag. Cheers PD
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #10 | ||
| | nutscratcher | Stilo | 29 | 23-01-2008 11:09 |
| | stesand | Punto | 2 | 28-11-2007 14:48 |
| | jedi_wookie | Stilo | 2 | 06-09-2007 10:08 |
